Well, for your information, Nick that asshole started this from the word go. He started all of the nit picking, digs, and generally being an asshole over anything. I know my stuff, and I have repaired many dodgy tunes and slap shop work. I don't even own a shop and I've already got many people coming my way because they are getting blatantly ripped off by other so called professionals.
If Nick wants to keep bagging me for no good reason whatsoever, then I will return the favor. As I said, lots of people have all said that's the general attitude he has.
Jam it in your ass too Force fed. You'd feel that same if you has some high and mighty thinking asshole trying to run down your business.
Oh, and for your information to how petty this started, the wanker started paying me out for a joke I posted towards Ben and Kingy, and then started making fun about me being in an accident where a dickhead run a red light and nearly killed me.
From there, it just proved that Nick was just out to be a complete f**kwit.
All the way back on page 21. And then he just kept picking like a 11 year old. Hasn't stopped since.
Edited by The Mafia
I have seen Andrew give that car a hard time and it not respond.... Clutch kicking the f**k out of it and it falling off boost.... With the new turbo n tune. Explain that
Edited by dysonest
Upfront and says what he thinks? I don't see a problem with that..
So you're saying if he never met you, didn't know anything about you, but went around telling everyone that you are a wanker, out of jealousy, you'd be ok with that?
answer my question jono ??
Didn't see that - But, I will answer your question.
The Car comes on boost at around 4500rpm. Its laggy because its only a 1.8 litre engine, with a largish turbo on it.
Here is the other issue - The car is too noisy, due to the external gate and no exhaust silencing what so ever so I cannot put timing into it safely until I have the ability to listen for detonation. The car does not have a knock sensor kit, so I will have to do it on the dyno, with a knock sensing kit. He also said that he is going be quieting it down.
There is also one other issue - The cams. He has told me that you put 280+ sized cams in the car. This means the power band will be pushed up very high making the car even laggier. People need to understand the bigger isn't always better when selecting cams. I had 256 cams in the 3.0L and it cam on boost very early and was very smooth, no lag at all.
One last thing, I was asked to just get it going safe enough to race at the drift track so I did. Before, it wouldn't even start, then when it did, it wouldn't rev past 2,000 due to the timing being completely f**ked up. After Blocka flashed the ECU without backing up the existing tune, he lost everything. Then I was handed a tune that I was told you did. I put that in, then removed it after I saw it. It was atrocious. I still have a copy. It would most likely grenade the engine if used. I then started from scratch.
With all of the problems that car had, I wasn't taking any chances what so ever.
Leon's car went perfect on the drift day, and he'll even tell you that about all his cars, as will all of my customers.
Edited by The Mafia
im not calling u a wanker to anyone, and im not jealous of u at all... if someone asks me about u, all i say is i dont like u.
that motor has 270 degree pon cams... yes it will make the power curve higher but hello its in a drift car anyway ??
and what ever tune u got handed it wasnt done by me... i never touched any tune on that motor
yes leons car did run fine on the day, even though it was blowing flames on decel. its not hard to tune a car "safe"
Leon requested those flames, so I put them there.
And I forgot to mention, half way Andrew blew a turbo to manifold gasket hence the really bad lag issues.
Bug cams in a drift may not be an issue, but when in a small motor that struggles to make boost early, I would have went smaller for better drivability.
You say all this stuff about tuning, yet you've never done it before by the sounds of it.
i have f**ked around with the tune on my 34.... and its not rocket science
and drivability ? it shouldnt see south of 4k sliding anyway. only on a take off but a clutch kick is all thats needed to be on boost. if the tunes good and not overly fuely making it heavy to breath
Edited by dysonest
Something interesting but last night I run into a small group of young fellas who actually brought you up in conversation pretty much straight away. (Ended up asking me for a tune too)
In their comments, you were definitely saying a lot more than you simply "not liking me". Actually, you talked a lot more shit.
This raises a couple of points.
First of all, they thought you were exactly what I said, negative, most likely jealous, and obviously deliberately trying to run me down due to some bullshit childish issue you have with me.
But my main point - You're a liar. So basically this removes any merit from anything you have said in this thread.
Now there is the possibility that you have lied to save face. And everyone knows that arguing with a liar is very much so a waste of time.
Here is an example, you just said you have f**ked with the tune in the Skyline. I've had three people on three separate occasions mention that you f**ked with that tune on that CA. And the tune that I have here, I can guarantee that a workshop would not do what is on this map. They would go bust within week if they pumped out tunes like that.
Anyway, lying about anything just to save face or to run someone down just makes you sink lower.
This is very poor form.
Edited by The Mafia
ur calling me a lair and u have NO proof at all.... i can say "i was talkin to 500 ppl last nite and they said u cant tune and ur a blah blah blah" and so this makes u a lair jono????...... a load of shit
unless u get them to actually tell me IN PERSON they were talkin to u and really think i am a negative person and for some reason jealous of u then how can i believe u ?? i cant
how many times do i have to tell u I NEVER TOUCHED THE TUNE ON THE CA.... i have on the skyline because i bought a wide band and datalog it.... plus i bought the 34 way after the CA was off the road. shit it was probly even in andrews hands by then. and i dont know who the "three" ppl u are talkin about are but obviously they are pissing in ur pocket.
It's all good Nick. I know not to believe you now.
And one good way of proving my point, when Andrews car was running like shit and he had to "clutch kick the f**k out of it" you went around telling everyone that the tune was shit.
When you only found out yesterday that he blew the shit out of the turbo to manifold gasket hence the lag issues.
Before it blew, the car was running great. I was there, I saw it myself. He just needs more practice at driving.
You're just another one of those guys who has or sees an issue and blames the tuner, without having a clue. You proved that yesterday. You really don't have a clue and just bag the shit out of people you don't even know. As I said, its a common jealousy thing.
Edited by The Mafia
he must have blew that gasket when his diff spat the crown wheel bolts then ?? because after he put a new hat on that diff housing it did nothing but run like shit...
and u provide a service to tune a car... if someone pays u for it then u have an obligation to get that car running great. regardless. and if u dont have a knock box then u shouldn't touch the car.
one thing ive learn is if u dont have the tools to do the job, ur work isnt gonna be good..... andrews tune = not good. plain and simple, get the correct tools so u can do the job properly and then i wouldnt have anything to complain about.
i work on cars everyday too, so im pretty sure i have some clue as to what would be wrong.... what do u do for a job ??
another mackay wannabe charging for half ass'd work. this towns full of them
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
