Thanks Sean, I will make another call. That dude must not have been too interested in selling me a car..
Jono,
Either call Ben or Vas, i had Ben over at my yard yesterday i told him i had a mate keen on an 86 he said there's one here to test drive but the wait is currently 3 months for the base model and 2 years for the GT-S or whatever the one is with the bodykit and spoiler.
Ben - 0400 422 628
Vasili - 0400 251 725
They will both help you out man.
Thanks mate, as soon as I get a chance I will organise something with one of these guys.
About oils earlier too, A mate sent me an interesting test of all oils. Seems Royal Purple and Penrite seem to be the best in these particular tests.
http://www.users.on.net/~pacey/sau/Oil%20Tests.pdf
Anyone know anyone who wants some of this stuff.
For Sale:
SR20 Forged Bottom end Package Used but in very good condition.
- Eagle Forge I-Beam Rods with ARP Bolts
- Venolia Forged Alloy Pistons measure 86.5mm
- Stock SR20 Crank has ACL Bearings but should be Replaced when rebuilding engine.
Take the lot for $700 ono
BENNY BOY THESE ARE H BEAM RODS MATE :domokun:
I think once i'm finally off these P plates i'll look for a tidy S15. Seems to be a shit load of SR20 bits and peices reasonably accessible and cheap rather than turning the V35 FI or throwing a Vortech on it.
thats why u mod cars lol... to be different. in saying that if u dont wanna spend BULK cash then yes lightly mod an S15, theres parts everywhere for them
Yeah there isn't many V35's in Aus that are Turbo'd or Supercharged so it would be interesting, but the only real downfall with my car is that there isn't a lot of people in the country that know a great deal about them and parts almost always have to be sourced from Japan/USA.
I still have 12 months.. so i got plenty of time to decide!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
