I think i just like them because they are obviously visually appealing cars and have a great motor and parts are easy to find and not overly expensive!
If i could drive a turbo and didn't have my V35, i reckon this would be a damn good car to start off on.
Check this one out, km's seem a bit too good to be true but i do love that pearl white colour - http://www.carsales.com.au/private/details/nissan-silvia-1999-13663393?base=1216&vertical=Car&cr=0&eapi=2&__N=1246%201252%201247%201282%204294963846%204294966407%20900%201216&num=15&silo=Stock&Range=Price%3a15000%2c20000%7e0.5&sort=default
S15's have probably the nicest interior of the Jap cars of that era. Although I do like the crazy digital dash in the Soarers (only good thing about them) the S15's are probably the pick for being the best overall
Yeah i like the dash cluster of the S15's. But there is a car i absolutely love the interior design of, a Supra! I was in my friend Taija's supra the other week, i love how it sort of curves around and everything is facing the driver. Some people don't like it but i think it looks super cool.
lmfao is that why u got a 33 ??
Black 33's are more win and have RB ;)
Serious?? When you dress it up a bit like Taija has it looks sick. At least that's my opinion!
Hate the way they look like a hummer or a truck, the centre faces to far towards the driver. The worst part is the dials but
Havent seen many dressed up but standard they look like puss
Fark yeah Big congrats to Under Suzuki in his Scorch racing S15 just broke the lap record at Tsukuba and stole the thunder off HKS CT230R Evo. absolutely smashed the record with a 52.6. Can't wait to see this car in the flesh at WTAC next yeah looks like it will be a massive show down between the Nemo Evo and the Scorch S15. Bring it on i say. This car is mental and is a huge inspiration for my 180sx build, want my car to be just like it. :woot: .
If you get a S15 first mod should be throwing out the 6speed box in favour for a Z32 box. They are made from glass :woot:
Really? In saying that, wouldn't that mean a CD009 box from the later model 350z/V35 would fit an S15?
far from glass... they are a resonable gearbox if maintained correctly and u use decent oils... make sure its always full and u shouldnt have a problem... unless u have enuff power to kick 3rd n 4th cos they have circlips in place n they are a little weak
Why don't people take it easy when it's raining? Last night coming home from slade point it was absolutely pissing down rain could not see 10m in front of me and it was basically flooding. Was crawling down that 100 zone doing about 50 and some f*ckhead was sitting on my arse. Some people piss me off!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
