Just watched a video by a cyclone chaser and he basically said that the rainfall we're going to get over the next 3 days is going to be close to 1000ml.. meant to be 300ml today and tomorrow and friday.. Starting to get quite nervous about leaving my car parked in a potential flood zone and at my house which is the same story. Wish i had a garage fuuuuuuuuuu.
Edited by Seano350GT
I'm over it already, pointless us being at work going to have no customers when it's pissing down rain. My backyard was almost flooded this morning lucky i had my car locked up in the garage at work overnight
My 2013 FJ Cruiser has been finally ordered won't be here March so time, have started ordering some parts for it. It will pretty much look like the yellow FJ below, except mine will be White and have slightly smaller tires. Can't wait to start tearing shit up. :yucky:
Coming soon:
- King Shocks 2-3" Lift
- Road Armour Bullbar
- Mickey Thompson Classic Lock II Black 17x9 Rims
- Mickey Thompson MTZ 285/70 R17 33" Tires
I'm actually looking at something smaller. Anyone got opinions of a Ford Kuga?
I know they are only a small SUV, but I just want a simple daily for now. They have the 5 cylinder turbo volvo motor in them, same as the XR5. 150kw and 300nm and AWD. Should easily hit over 200kw with an edit.
With a decent engine and AWD, I thought it might be a good setup.
and yes, I know Bennys FJ would probably run right over the top of it, lol.
Go for a Prado Jono.. 150 series (current model) a couple of years old with low km's is going to cost you mid 50's depending on the model. I would go for a GXL personally.
Keep in mind too a Toyota is going to hold it's value better than most other cars in the market and they are damn reliable. I have a few here at work mate.
Prado is the same chassis as the FJ Cruiser, same engine etc. and the FJ is 50K new. All other Toyota's are over priced and they come with f**k all features compared to other car makers, only paying for the name.
Shocks and Bullbar ordered now i'm broke :( not a bad way to spend 6K, still deciding on rims its a hard choice, i sent a email to USA for a Set of TRD Beadlock rims, and Transit Tyres in Mackay wanted $480 a tire for MT MTZ .... f**k that can get BFG Mud Terrains for Tirerack.com for $200 each.
I agree Ben, but i prefer the Prado interior probably the only thing i don't like about the FJ is the square windscreen doesn't feel like there's much vision out the front of the car but other than that i like them.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
