Just received an e-mail from Will at JHH. After a lot of miscommunication and non-communication... My block is assembled... And my head has been ported, guides installed and valve seats cut. All that is left is the clean and final assembly! :):):):):)
bababababannnnggg!
I'm confident! :)
Put the tensioners on tomorrow or monday if I get a chance then the head can go on, put the timing belt on, make sure the pistons dont hit the valves (important step lol) and then I'll be running out of excuses. May take the Skyline off the road next time I'm home from work and pull the other engine out, send the clutch away and have it ready to put the new one in the round after
I REALLY am running out of excuses not to finish it now
More photos, today made some pretty big steps :)
Manifold and turbo arent bolted on at the moment, just there for some final alignment/modifications. So hopefully will pull the car off the road next time I'm back from work, work out the dump/wastegate setup and then get it all happening :)
Looks like an dirty old diesel turbo Cal.
Get off the drugs :P
I'm keen for first startup but will be a bit nervous as well to see if the oil control is gonna be alright.
I've always been a fan of s15's. They feel alot faster with minimal mods compared to skylines at least. 3071 and supporting mods would be fun enough
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
