Motor Mayhem has been called off but still trying our hardest to get the car ready. :wacko:
Here's a vid of new 4" Titanium Side Pipe revving at 7200rpm
and Pics of new Parachutes and Fuel Tank setup
881936_10200963168708555_1681359028_o.jp
903558_10200963168508550_1503738912_o.jp
Had a bit of a play with the link today, just ran a boost line from the engine bay through the window and into the ECU to get some sort of air measurement so it would run :)
Got the thing to idle fairly nicely after spending 5-10mins on the tune. Might try and get a better base map to work off. Doesnt return to idle to nicely at the moment but should be all good when I have more time to play and the IAT sensor and external 4 bar MAP sensor is in.
Just good to be home after work and being away, holidays suck when you go out to work straight after you come back
Running the GTR this weekend benny?
also, does anyone want to change my drivers side door lock actuator for me? it's a bit tricky i don't want to take the window out and i don't feel all that confident doing it. Would be happy to pay, got the new actuator here ready to go hit me up if your keen.
yup
yup
ok see you soon.
Nah man will be at work the GTR will not be appearing this year.
Sent from my iPad using Tapatalk HD
Damn how come no races for the rest of the year? that sucks keen to see you smash a record.
If anyone needs a mod plate for their car (most of us do) contact Mick Zammit and see if he has any spare spots there is a bloke from Brisbane coming up on the 10th to the 12th of May.
Rules have changed apparently and any modification from injectors, surge tank, turbos, cams, the lot will need to have a mod plate for as of May. Just gives the cops a few less things to pin us for if its all covered. ;)
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
