Motor Mayhem has been called off but still trying our hardest to get the car ready. :wacko:
Here's a vid of new 4" Titanium Side Pipe revving at 7200rpm
and Pics of new Parachutes and Fuel Tank setup
881936_10200963168708555_1681359028_o.jp
903558_10200963168508550_1503738912_o.jp
Had a bit of a play with the link today, just ran a boost line from the engine bay through the window and into the ECU to get some sort of air measurement so it would run :)
Got the thing to idle fairly nicely after spending 5-10mins on the tune. Might try and get a better base map to work off. Doesnt return to idle to nicely at the moment but should be all good when I have more time to play and the IAT sensor and external 4 bar MAP sensor is in.
Just good to be home after work and being away, holidays suck when you go out to work straight after you come back
Running the GTR this weekend benny?
also, does anyone want to change my drivers side door lock actuator for me? it's a bit tricky i don't want to take the window out and i don't feel all that confident doing it. Would be happy to pay, got the new actuator here ready to go hit me up if your keen.
yup
yup
ok see you soon.
Nah man will be at work the GTR will not be appearing this year.
Sent from my iPad using Tapatalk HD
Damn how come no races for the rest of the year? that sucks keen to see you smash a record.
If anyone needs a mod plate for their car (most of us do) contact Mick Zammit and see if he has any spare spots there is a bloke from Brisbane coming up on the 10th to the 12th of May.
Rules have changed apparently and any modification from injectors, surge tank, turbos, cams, the lot will need to have a mod plate for as of May. Just gives the cops a few less things to pin us for if its all covered. ;)
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
