Yeah tomoro night. Ill head back down when i put new comp in and tune new turbo. Speaking of which did u still have the data logger for the d jetro , and the intake that had those fittings in ben. Make it a swap not a drill out and tap
Ah I go to work tomorrow night but I will be attending Slamfest next weekend at Palmyra.
The GTR will not be attending. The engine has currently been removed, the clutch was absolutely rooted, has been sent to NPC for rebuild and slight modification. Engine got all packaged up today and overnight freighted to Godzilla Motorsport for a B'day rebuild / freshen up. The block is getting grout filled solid so will be stronger, block is also getting O'ring treatment, head getting super-tech valvetrain for higher RPM, new Maran 5000cc fuel injectors for the Methanol Fuel, plus other this maybe. All in name of more power and torque will be up around 1400HP :woot: that should increase our top end MPH and get the low 8's.
Yeah I got all the datalogger gear hear Jordan just got to come get it, as for drilling out No.3 &4 intake runners for the map sensor fittings, I got another idea for that, save you pulling the whole plenum off. I will do it how Kingy's old D Jetro setup was and use the 2 points at either end of the air equaliser rail. It worked fine on his car.I'll try catch up with you next week and show you.
I know lol. Depending on what he wants to get out of it, FC-Pro graphs and records data alot better then FC edit will. But FC edit might be all he needs. Offer is there Jordan if you want to do some data logging
I have no clue lol. I just need it for grant so he can tune it once its in. And it will be going to vipec or something in the future just want to get rid of afms. When are u home ben. Im heading out of town tomoro for a week or so. So if next werkend ur free ill come round. And will let u know cal cheers for that.
Ahh ok
Yeah I perfer FC-Edit for tuning. FC-Pro is just great for logging if you have a problem. You can record a run and then play it back and view around 12 parameters at the same time on playback. its a good program
ah righto, to easy cal, ill let grant know and see which one he would want. matt came round and i seen what you was talking bout ben. easy as. just a splice into the boost lines, just need a few t pieces from somewhere and should have it sorted within the month.
Just in case anyone is interested. I have some AH Astra headlights I want to get rid of. Trying to sell them for $20 on facebook but free to anyone on here who wnats them. Bit of a long shot anyway. The lenses are just a bit yellowed, other then that no real issues
Let me know
For those who missed it on Facebook, going to do a little plug for Craved Coatings here. Did a fantastic job of my cam covers, very happy with the colour and finish on them. They look great in real life
Photos:
1048514_10151487800167793_2038528849_o_z
1063742_10151487802862793_1199754537_o_z
They're pretty average quality photos as they are only off my phone but you get the idea :)
Got a better set of injectors sitting in the shed if anyone is planning on running over 500hp on E85. I got 6x 2000cc ID injectors have proven to make over 1000HP old drag car injector, or maybe I keep them for my next project.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
