Hey E_Lu-SHuN
Fitted my PFC and ran it up and the air con and everything works fine. The only thing I did notice was that it sounded like the controls for the fan unit where it diverts it to the face/feet/window etc. made some clicking noises then after a few seconds it went away.
Sounds like the air con issue is happening to a few guys, could be a setting in the control unit maybe if its happened to a few people?
Giulian
  • 3 weeks later...
OK so i all the mech stuff done now.
On to the wiring, mine seems to be similar as someone else posted, when i neutral the reverse switch cicruit is closed, when in reverse it opens. How do i get around this?
And the speedo sensor plug is different, some people's seem to be the same? Can i just wire this up to the one in the car?
hey, thats the one thing that i forgot to document...the speed signal. i know i didnt change mine so it must of been wired up to the plug..ill double check with that...have to get under the car.
reverse circuit closed, so the reverse light goes on?
if thats the case, then u hooked it up to the neutral switch..
test the switch out to find which one is the reverse switch by putting the gb in reverse...and then getting a multi meter to test for continuity
Its definatley the switch with the brown wire's.
I'll get back underneath it when im back from work and have a look.
I was hoping to not have to buy a R34 speed sensor, but by the looks of it i will, unless i can just wire this one up?
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
Hi SAU Thanks guys your posts have helped heaps. I have a 98 r34gtt auto with 92,000 kms i picked up for a crazy 9k 6 weeks ago and the thing is after I spent all this money on a R33gtst which until some drunk knob nearly killed me my 'Blue Phantom' had a fully rebuilt/stroked/forged engine running gt3570r turbo with microtech computer. It was running 270rwkw on 14p. Just needed bigger injectors and it wouldve been fun. LOL. Lucky i got my payout n bought car back for peanuts. Anyways I still have the engine/gearbox/clutch/ecu etc. As i have all the parts execpt the lines I was quoted $600 to install everything. I guess I'd need a manual ecu and new cluster. I have put my tein na coilovers from the r33 into the 34, the front mount, front slotted rotors. I wrecked the car myself and have rebuilt a cbr rr 250 with a mate when eveyone told me to sell it. If i hadn't I for sure wouldn't have done all the stuff with the r33/r34. So thanks guys I may atempt the conversion with a mate and save the the $600.
sorry about the pics guys, it will be up and runnning again shortly after i get my domain renewed...expired 40days ago..to reactivate costs $US135, wait an extra 40days for the domain to go public will only cost $US9 to register again...go figure ;)
Hey Blue phantom,
You dont need a ECU, Auto ECU will still run and the cluster will still work, the good thing with the auto cluster is that when we engage reverse...the REVERSE symbol on the cluster lights up!
can someone just confirm that ALL parts (excluding gearbox) required are:
r33 clutch kit
r33/34 manual tailshaft
r33/34 flywheel
r33/34 manual spigot bush
r33/34 clutch master cylinder
r33/34 slave cylinder
r33/34 clutch master to slave cylinder lines
r33/34 pedal assembly
am i missing something?
  • 4 weeks later...
  • 1 month later...
Mate, just onequestion...
what will happen to the speed sensor on manual box..? please explain. im bit confuse. i'm just about to do the r33 manual convertion.
  • 1 month later...
I have this same prob. Any ideas? I've tried both switches, I def have the right one hooked up...
  • 4 weeks later...
Ok this is my first post.. Im new to this world of nissan. I have recently got a 99 stagea rwd auto. Its a RB25det Neo. Is this a r33 or 34 motor? Now having made my self look a twat to all you hard core nissaners could this conversion be done to my stag?? If so has anyone done it?? I like my car its very clean and low kms so i think its worth the effort? any opinions and suggestions would be great. thumbsup.gif
rb25det is in both the R33 and R34, however only the R34 has the rb25det with the NEO head (the engine cover will have 'neo' printed on it) and if you really like your car and can be bothered doing the conversion then go ahead but it is a lot of effort and most people will say just sell it and buy a manual, but it's up to you who cares what others think right?
  • 2 months later...
Hey mate
great tutorial thanks for taking the time to write it.
Am going to print this and give it to my mechanic to do the conversion once I sort all the parts, thanks again!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
