Just wondering if this has happened to anyone else or if anyone knows what may have caused this. I was approaching a green arrow which turned amber, I decided to stop..it was a controled but qick stop..the car stalled just as it stopped...it started again ..and didnt do anything unusual after. Just seemed a bit weird.Any thoughts?
Cheers
Scott.
It is an auto by the way.....
Edited by bluesky4me
Falcon used to do this. Something to do with the vacuum from the engine which powers the brakes being overwhelmed by the sudden change in pressure and stalling the engine. Maybe. Thats what i was told, anyway.
mine has done that like 3 times in the past couple of months.. under sudden braking...not stalled to a point where it dies off...but rather the idling was slightly unstable.
I'm using the stock bov with only a larger exhaust for mods...will get my safc installed to see if that solves it...else i might get a hks eids to stablise the idle.
it affects manual cars as well.
there is a massive thread on this in forced induction.
you can tune around it with aftermarket ECU's but why have your car run pig rich for a few seconds for NO performance gain??
factory BOV works fine so why not use it and spend your money on things that improve the car.
hi there mate i had the same problem i have a 97 stagea it has a upmount to4 turbo with a external wastegate.
i use to have a blow off vavule that use to vent in to the atmosphere what u need to do is to get a blow off vavule that vents back into ur turbo then ur car wont stall if that doest not work then there is something else wrong with ur motor.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
