Hey there,
I know that most of you properly know about the new shell fuel called V Power that has now replaced the Optimax fuel that alot of Skyines drivers run in there cars, however a few nights ago speaking to the lady at my local fuel station she told me about V Power Racing, and I had a bit of a chat to her about it.
Now, at this stage V Power Racing isn't at many Shell Servos, only selected ones I belive, I think within a 20-30KM radis from where I live there is only two servos that have the new V Power Racing.
It is susspose to be more fuel efficent, cleans your pistons etc.
Here's what shell say in there little book:
Shell Unleaded: Regular fuel containing a fuel economy formula designed to take you furthur.
Shell Unleded 95: Quality fuel that features an octane rating of 95 which is perfect for drivers of many new cars, especialy new European and Japanese cars.
Shell V Power: 98 octane premium performance fuel that can keep a new car performing like new for longer and in some cases can help rejuvenate older cars.
Shell V Power Racing: Australias only 100 octane fuel with 5% ethanol designed to allow many modern and high performance cars to perform at their peak.
Would running V Power Racing in Skylines weather they be GTS, GTST, GTR, GTT be good for the car and better on performance? Has anyone use V Power Racing? If so, what are your comments on it?
I haven't used V Power Racing, but I am using V Power it seems the same as the old Optimax to be honest, although the fuel has been designed byFerrari.
https://www.sau.com.au/forums/topic/140171-v-power-vs-v-power-racing/
V Power = Optimax
V Power Racing = Optimax Extreme
I believe V Power Racing is only beneficial if you have your car tuned to take advantage of the ethanol factor.
Thats what I thought, but thought the standard ECU might be able to throw a bit more timing at the motor after it adjusted to the 100ron?
not reccommended for nissans older than 2004, not sure if this applies to imports... should notice a difference in stock ECU cars, AFTERMARKET TUNES- could be a problem, they dont adapt to different fuels, and ethanol has a higher oxygen content so could cause them to run lean...
I havent done any high tech fuel analysis or anything, but what i can tell you is filling up with v power racing in melbourne near the westgat and driving to albury on one tank the car ran great, smooth, heaps of power to overtake.
In albury they didnt have the racing one, so i went the shell v power.
Felt like driving a hyundai excel.
No power, chewed the fuel and ran like crap.
My 'test car' is a 1996 series 2 with some mild tuning, std turbo and other bolt on bits and pieces.
shell v power racing - good
shell v power - bad
Its a clear exmple of text book marketing strategy, same fuel but a differnt branding or name to be more unique from its competitiors and also attract more customers.
V power clearly sounds better, grabs your attention than Optimax
I beat you the V power fuel quality is still as same as the old one Optimax, as for the new one V power racing thats probably the improved fuel.
I regularily use vortex, and will continue. I had to fill up at shell and used v power and found that i didnt get as many kms as i normally do. i might try the 100 ron but i agree that it is purely a marketing strategy to change the name...dont think its different.
Its funny that V power racing is more expensive than V power when all they have done is take 5% of the expensive 98 octane petrol out and put in 5% ethanol which is very cheap...
Really, V power racing should be CHEAPER than V power, as it has ethanol in it.
http://www.skylinesaustralia.com/forums/in...&hl=Kennedy
SK is on the case about V power racing so I'm staying tuned for his results.
I'm on my 4th tank of VPR now and can definitly feel a touch more responsive than extreme
  • 1 month later...
I've been using V Power Racing lately, it seems to have a better response in my car and it runs very smoothly.
Had friends in the car have even asked me what have I done recently, its running so smooth.
Haven't had any problems as yet and been using it for a few weeks now, seems like good stuff ..one bad thing though..
I ain't liking the price!
Has anyone actually changed there old rubber fuel hoses?? I was under the assumption that ethanol based fuels will harden these older hoses that we are running making them crack and get brittle?? Can someone correct me here?
Cheers
A
Been using 100 ron in the R33GTST since January (almost 12 months). I put an adjustable FPR in recently to raise the fuel pressure and a GTR fuel pump. I checked the fuel lines at the same time and they are in perfect condition.
:D cheers :D
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
