work has their xmas party on saturday night but if not too hung over ill come!! :(
haha i've got a mates 21'st the sat nite aswell, looks like both of us will be seedy :D
P.S going in a 33 FTL!!!! :P
  • Replies 565
Beats walking!
I am sure I can bet someone else to drive it :P
hey i wasnt bagging it, i was just saying i woulda liked to be there in my gtr!
and andy, if u dont want ur 32 to be outshined by ur 33, give me the 32 for a day and i'll give it some tlc :D
hey does anyone wanna meet at carindale or there abouts?
and then jump in the line with the springwood guys when they come past?
just a thought :P
yeah mate that doesnt sound like a bad idea
Ahh bad news for me guys, blew my turbo last night. Thought about just fixing that by replacing it but have decided to get all the work i want done to the car, so im aiming for 350-400 HP. All the best with the cruise!
Tim
Tim
softcork :)
just a thought :)
Carindale sounds good. What time you wanna meet up. :laugh:
The red circle is where Maccas is located and the blue line is the route we will take to the motorway, just before the motorway marked in purple is where we will regroup before the onramp (depending on numbers).
I can't wait, this is going to be awesome!
Just to update numbers, I'll have at least 3 of us coming, possibly 5. I'll be meeting the crew at Springwood Maccas'
How many people are going to be meeting at Springwood Maccas?
Carindale sounds good. What time you wanna meet up. :ninja:
well if the springwood guys are meeting at 8 and leaving at 8:30 if we make sure we are ready by 8:30 then it should be all good... we might just have to get one of the springwood guys to give us a heads up when they are coming past the old cleveland exit so we can jump on...
any ideas where to meet? i was thinking somewhere where we can see them coming would be good but not sure where... would probably only be 3 or 4 of us so we dont need too much space... (might go and check it out tonight and see)
or u could not be slack and meet at springwood maccas...im coming from ipswich for christ sake :ninja:
yeah i am slack... its cos i dont like backtracking - especially when im hungover :)
Hey Zennon, what about the truck stop actually on the gateway...heaps of room to pull over...
Yeah sounds good! This is the one your thinking of isn't it:
Lets meet there at 8:30 then
just for in case my mobile number is 0433201831
PS. noone is allowed to laugh at my cracked front bar :ninja:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
