  • Replies 565
Ok some of the video i shot is up...
I have a full video im currentlly editing with music and photos...
All the raw pictures and video have been sent to ignition dvd and ill update you all when I hear from them...
Marc, where did you get the VINYL work done on your 32, I have been racking my brain for ideas, and you come up with the perfect layout on a 32..............thanks
Yeah it is pretty sweet, I needed something that would really contrast against the smooth curves and aerodynamic bodywork of the vehicle.
At least it does skids
PS that was my birthday present from Nexus9 stop whoring it around :ninja:
Haha yeah I remember "borrowing" it from a post on SAU, couldn't remember where though. Now that you mention it, the 32 definitely looks to have been touched by the hand of Nex... :thanks:
and you took what i said seriously :w00t:
i was having a joke dude
Haha fair enough, I'm going to blame tiredness for me completely missing it. That's my story and I'm sticking to it :(
only because it has an RB25 in it.
Thats why it is easy for me to compare wich is the better car :ninja: when the RB20 handicap is gone it is no contest!
Any way each to thier own, I like both my cars :(
What twins?? You mean the S2's??? They don't even have the same rear wing Frank!! Too close to stock to be my twins!! Plus the owners are tiny little guys!!
Where is my oil catch can!!!!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
