Hey guys,
I think it would be good to get a list of people who have entered.
Saturday...
weevil - Chris - 60
aza- ?
r32 zilla - Tim - 23
stretch - Greg - 696
steve gts4 - Steve - 117
Sunday...
aza
i can edit post and add people if ya like?
mods - that cool?
https://www.sau.com.au/forums/topic/140428-bathurst-speed-weekend-entrants/
  • Replies 68
  • 5 weeks later...
:ermm: sorry guys we are assembling the motor this weekend....so much for having it in the car by now - these things always take longer than yo expect.
Have a great weekend, its good to see a few SAU people heading along :laugh:
its a great event. hope the weather is fine and alls good. those that are going we should organise to go out on saturday night. we always go to stumpys on stuart for dinner. im with several guys from the renew club and there rotors. always good food and beer/burbon,.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
