Hey guys if anyone can tell me what a stock R32 gtr would make on the dyno, and then what I can expect from my gtr which is being built up at the moment.
My car will have a 3" exhaust, Apexi power fc, N1 turbos, forged pistons, stainless head gasket, and maybe pod filters.
Any help would be great, Im a while away from getting it, and Id love to get an idea of what kind of power she might make.
Thanks.
https://www.sau.com.au/forums/topic/140429-r32-gtr-power-output/
well my GTR is pretty much standard apart from full 3 inch exhaust , pod filters and 13 Psi of boost and mine made 238 rwkw.
Thats impressive, mine is running 240rwkw with pods, dumps, exhaust, r34 turbos, PFC, 15psi, dialled cam gears, 600cc injectors, fuel pump.
With just pods, turbos, dumps and exhaust made 218rwkw.
Stock is 176kw (206 at the flywheel).
I got mine to 261rwkw with ARC airbox, new turbo back exhaust, microtech lt12s and a $40 boost controller which never spiked
Note though: No difference between an OEM airbox and an s-tune filter (Thanks powerplay) and the ARC box at that power level
N1's should be above 300rwkw id guess, but you will know soon enough :P
The 206kw figure that was listed by Nissan was not realistic and only given as there was a gentleman's agreement in japan that no japanese car manufacturer would produce a car with more than 206kw. You will find a few japanese cars with that magic 206kw figure in their brochures. Multiple sources list the real power output of the GTR being more like 320hp (240kw) at the engine obviously...
sweet thanks
what power gains do you usually get from just a ECU upgrade?
right now my gtr is in the shop getting a microtech ltx12 ecu with bosch coils and an ignition pack installed
i know it really depends on tune and tuner just curious is all
And should i play with the tune of the new ecu for a while or grab some adj. cam gears and play with that?
Thanks
RellikZephyr
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
