  • Replies 120
yup that will be fine bro, just remind me on the day, if the rest of you are time specific please lemme know so we cvan draw up a schedule, otherwise interloper goes first and the rest of us can go as we feel like it, thats if we are having the BBQ, please show some hands for the bqq or not ? wanna get this arranged in stone :P
dAVE - nope sorry, not enough people to run another day, :P
Originally posted by aybee
ill go around 1, plenty of time to sleep in.
no for bbq, that night is my 21st so probably doing stuff
All lies!!!
i just remebered ive gotta play footy which will be about 10 or 11 so will have to go first or second. hope thats cool. would prefer second but dont going at 8.30 if i have to.
cheers
Sorry people i don't want to get there early then have to wait for ages because people are making excuses to get in early and leave. If you have other commitments then do it in your own time.
I liked the idea that was suggested by R31Nismoid, the cars get done in the order you arrive in. This is a fair way to do thing, as everyone else also have other obligations. I am 'on call' for work on that day, but have arranged with a collegue to cover me while i am at tint-a-car. So do i get primary status to get my car done first or second? NO, but i will be there as early as possible, so i can go back to work if i am required!
Don't mean to be a prick, but we all have our own resposibilites and i think work is more important than a game, and i am still not asking for special privledges. The only person who can most welcomely 'jump the que' would be DJ-L3thal as he got off his A55 and organised this for us!
Alan
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
