i had some stupid kids try that receipt trick on my car, where they put the receipt on your back window and when you get out they jump in and drive off. thankfully i was smarter then that and took my keys with me. so when they came near it i told them i would kick there ass if they went near my car again.
some people really have a nerve. so anyone know of any good alarm systems?
there black now. and yeh she is stock except the muff. let us know how much and ill check out my finances. my 18th is putting a pretty hole in my pocket at the moment lol. because i have rego, insurance and a party to pay for...its good fun. but let me know and i might hold off the trial body kit for anotehr month.
you can have the zorst for $120
In otehr words ill get it, but ill have to check it out first is all.
Just watch if the exhaust came off a coupe as the sedans are longer by about 60 to 70mm and the exhaust might be short, simple fix thought just get it extended.
I saw a guy from sau fit a exhaust the other day to a sedan ( one of the kit full exhaust of the net)and by the looks of things was supplied a coupe and he ran into drama's with the rear muffler sitting to far in and too close to the bumper which in time cause it to burn the bar.
yeh i know all about that, but dattoman knows i got a 4 door so he would know if it would fit or not. thanks for lettingu sknow thou
not unless her measured it and knew the length of a coupe and sedan exhaust,but good luck if it works sweet
Also not sure if 33's are the same as 34's but my sedan i got a nismo brand muffler and it apparently had come off a coupe but to fit the sedan it needed to be extended as mentioned above but also new brackets put in place as the fitment was not in the same location as coupe.
yea that was me.
should be getting zorst extended next week.
Hey guys,
Just a quick heads up - we have a BBQ and Cruise happening this Saturday morning. EVERYONE is welcome! (we have 50+ names down to attend)
I know a few guys from the gold coast are head on up. Anyone planning to come down from the sunny coast?
if anyone is coming down, can one of you guys organise a meeting point so you guys can cruise up together?
We've got a breafast BBQ happening - arrive at 9am, start the cruise at approx 10.30, ending with lunch at the pub 12noon. For more info, check out the post in the event section -- here
an early start for you guys, but should be a good day!
well i dont know but im sure none of the guys actually read this in time and if they did they probably are already there. i cant go car is getting fixed, but sounds like a good meet up. P.S best place for sunnycoast ppl to meet for events is ettamogah pub, its just off the highway and is fairly central to everybody to go to meets.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
