William, Won't be slipping as there is nothing to slip, sounds like it could be your shif solenoids. check on the forum as there probably is a work around for the ECU codes. it is something like turn your car to acc, turn it off, and on again, then shif into neutral, turn it off, turn on again, then shift down through the gears holding your foot on the brake. or something crazy like that. Do you have an A/T light on the dash. if so that will probably indicate an issue, but run the diagnostics. if not just take it to Ron Hill in Kayleigh drive in maroochydore. really knows his stuff and can get the solenoids in overnight
hey, does anyone have a set of decent coil packs laying around that they dont mind me borrowing, i think i have a problem with mine would like to test some others that i know are working fine to see if it solves the issue. or someone come suss the car out when its playin up.
any help is appreciated.
hook up your volt tester and check'em out dude.
quicker way then waitin for someone to lend you one and chang'em over.
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
