Hi
I just had a intercooler installed and im noticing sum problems. While I drive if I go to give it a bit sometimes it'll react like it's suppose to but sometimes the engine will cut out and only the turbo opens and then the whole car jerks 2 or 4 times with the engine kicking back in and then it drives normal or it will happen while im just cruising and I also get no feedback from the accelerator peddle. It's starting to bother and worry me so any help is greatly appreciated. This has also happened once or twice before it was installed so is it the intercooler or something else????????
https://www.sau.com.au/forums/topic/140794-engine-trouble/
how much boost are you running? what other mods does the car have?
Just an aftermarket Kakikomoto exhaust system and HKS pod filter, Blitz Boost gauge and turbo timer. The boost is running standard. You know of any ways of fixing it? Should I upgrade to a new ECU as I will be doing this eventually or would I basically have similiar problems?
https://www.sau.com.au/forums/topic/140794-engine-trouble/#findComment-2623198
I've checked the vacuum hose and i couldn't see anything wrong. Is it possible that maybe one of the hose clamps aren't on tight enough and a bit of air is being leaked out or something cause they don't have any slits in either. Also does anyone know where to get a proper car manual for a 95 R33 GTST Skyline?
https://www.sau.com.au/forums/topic/140794-engine-trouble/#findComment-2624657
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
