when i give the car a boot from 2nd gear i sometimes notice smoke in my rear view mirror, i got the car tuned a few months back and everything was fine, so i'm just wondering if i should be worried or not, btw, i hardly ever even boot the car most of the time i drive normal, i don't know if this could be the reason.
last few months i used motul chrono 300v, and two days ago i switched to turbo light 4100, even before i started using these oils i would sometimes notice the smoke, it doesn't always happen.
thanks
the mods i have
pfc
fmic
cai pod
bleed valve
3inch exhaust - full
Edited by Hulk1010
https://www.sau.com.au/forums/topic/140801-smoke-when-booting/
i might aswell add this here instead of making another thread, For the first time earlier on tonight when i gave the car a boot from second a small orange light flashed a few times to the right of the speedo, i then checked the knock and it read 65, the car pulled good, iv just never seen this light come on when driving, this was the first time. Also since i got the car retuned i haven't got any high knocks, this was also the first high knock
Do you have a catch can fitted? preferrably externally vented, if you must plumb it back, make sure its properly baffled
blow by is something that alot of people seem to overlook
And personally I would be taking the car back to the tuner and asking him to recheck the tune, it may just be that your plugs are not up to task, or some other cause - but if you are suddenly getting higher than normal knock, something is amiss and your tune may need attention.
no i don't have a catch can fitted, is it important?, just before the tune i got new irridium plugs put in, the tuner double checked them to see if they were gaped correctly every thing was fine
THrow the iridiums away personally... Heard of quite a few RBs misfiring and carrying on with iridiums in.
Also, white/grey smoke, can also be oil from the turbo.
Blue smoke is BURNT oil ( In combustion ) white/grey can be oil getting around the seals in the turbo and straight into the exhaust, so it's not actually burning, but vapourising.
If you don't beleive me. Go heat some oil in a sauce pan (Don't get it explosively hot) but a fair bit hot, and watch the smoke that rises.
from what has been described, its not turbo seals.
Hulk 1010, a catch can is very important, and so often overlooked.
It stops crank case gasses (blow by) being recirculated through the intercooler, but more importantly stops oil from blow by going into the combustion chamber. Blow decrreases the intercooler efficiency, and can cause detonation.
The harder you lean on an engine (more power) the more blow by you will get.
RBs do breath a fair bit, especially so if you use too light an oil - 3g 5w50
The smoke coming out of the exhaust - from what you've said, sounds pretty normal - the high knock reading is worth getting checked.
Instead of listening to everybody on here - take it to your tuner/mechanic and let them sort it. Without seeing the smoke first hand, its pretty damn hard to say for 100% certain, if you have something to be worried about or not.
thanks for all the replys
Iv been looking at a few catch cans on various sites, what would a reasonable price be for one? the ones from overseas appear cheaper but i don't really want to wait a long time for the product to arrive, also i'm not sure about the hosing size.
thanks
these are some of the ones iv come across
http://www.nengun.com/catalogue/search/
http://www.slidingperformance.com/catalog/...amp;x=0&y=0
The greddy square type can be opened, and you can put filling (copper wire scourers work well) in them to catch the suspended oil particulate from the blow by - would be my recommendation
The come with all the clamps, quality hoses and mounting brackets and are great quality
cusco type would be fine if you are not plumbing it back in, but external vented is NOT street legal
your choice :D
i was driving around a bit earlier on, about 25 mins in is when i saw the smoke
9:04pm... Thats night time.
Don't use the revision mirror at night to tell if you are blowing smoke or not as it always looks as if you are, especially with head lights behind you.
Get the other half to drive the car and you drive behind. Best and most accurate way to test. Providing she is familiar with the car and isn't freaked to boot second. :D
I've always seen a slight haze in the revision mirror when booting it at night with the person behind with their lights on.
After reading the mods done to the car & reading these comments I'd have to say this does make perfect sense. I've got a friend with an S14 who had to put a catch tank in after similar mods as he was loosing stacks of oil (Partly to do with the fact that he couldn't turn boost below about 16 PSI!) Catch tank cured his issues. Surprised the workshop hadn't suggest you fit one too.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
