Hey Guys,
I've spent the last 2 hours searching and can't find it.
Can anyone link me or;
1) tell me the differences between the R33 turbos.
2) Which one is best suited to the RB20.
3) I know you need to make sure you get "the elbow" for the conversion...but what is it? What does it look like?
4) Any other things I should do first? Fuel pump perhaps? Will I need a SAFC or similar aswell?
Cheers
Chris
Edited by eXc
Hey,
Get the R34 Turbo!
I have a R34 Turbo on my RB20 and it runs really well! Bolted straight on and used the RB20 Actuator to get the stock 10psi. Boost starts just before 3000revs and Full boost comes on just before 4000revs. :D
Edited by r32matt
1. i dunno but i would like to find out. i recently just too my S1 turbo off and replaced it with an S2 (because the S1 was rooted) and noticed that the design of the compressor wheel was a little different. the smaller blades did not protrude past the tip of the bigger blades.
and the S1 has a steel compressor where as the S2 has a nylon compressor
2. the S2 is supposed to spool faster due to the lower rotational mass, and seeing as rb20s cant spool turbos well, this would be better.
3. the elbow is the compressor outlet. go have a look at your turbo, it is the first pipe that comes off of your turbo, and goes into your intercooler piping
4. fuel pump is definitely a good idea, and you really should do it, just in case. another good bang for buck mod is to get your ECU remapped. cheap and just as effective as stand alone ECUs. and come with all the stock knock sensors, cold start crap etc
The r34 turbo, is pretty laggy i think (has the same sized exhaust wheel as the vg30). In first it doesnt start spooling to about 3-3.5k so it makes taking off sort of hard, it does kick in hard at about 4.5k though. The performance increase wasn't all that great for me, i got a remap at the same time and achieved only 164 rwkw (on the same dyno, that i had had it measured, close to stock, at 133rwkw)
i will upgrade to cgc hi flowed series 2 r33 turbo soonish
Unless i get off my P's before then, and can get a GTR
S1 is definitely still worth it
easy to tell the different compressors, one is aluminium and the other is nylon. they feel much different
and the number on the comp cover is different
i think the S2 has 45v4 and S1 has 45v3
may need someone to confirm, thats just going by my crappy memory :D
Edited by salad
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
