Hey Guys,
I've spent the last 2 hours searching and can't find it.
Can anyone link me or;
1) tell me the differences between the R33 turbos.
2) Which one is best suited to the RB20.
3) I know you need to make sure you get "the elbow" for the conversion...but what is it? What does it look like?
4) Any other things I should do first? Fuel pump perhaps? Will I need a SAFC or similar aswell?
Cheers
Chris
Edited by eXc
Hey,
Get the R34 Turbo!
I have a R34 Turbo on my RB20 and it runs really well! Bolted straight on and used the RB20 Actuator to get the stock 10psi. Boost starts just before 3000revs and Full boost comes on just before 4000revs. :D
Edited by r32matt
1. i dunno but i would like to find out. i recently just too my S1 turbo off and replaced it with an S2 (because the S1 was rooted) and noticed that the design of the compressor wheel was a little different. the smaller blades did not protrude past the tip of the bigger blades.
and the S1 has a steel compressor where as the S2 has a nylon compressor
2. the S2 is supposed to spool faster due to the lower rotational mass, and seeing as rb20s cant spool turbos well, this would be better.
3. the elbow is the compressor outlet. go have a look at your turbo, it is the first pipe that comes off of your turbo, and goes into your intercooler piping
4. fuel pump is definitely a good idea, and you really should do it, just in case. another good bang for buck mod is to get your ECU remapped. cheap and just as effective as stand alone ECUs. and come with all the stock knock sensors, cold start crap etc
The r34 turbo, is pretty laggy i think (has the same sized exhaust wheel as the vg30). In first it doesnt start spooling to about 3-3.5k so it makes taking off sort of hard, it does kick in hard at about 4.5k though. The performance increase wasn't all that great for me, i got a remap at the same time and achieved only 164 rwkw (on the same dyno, that i had had it measured, close to stock, at 133rwkw)
i will upgrade to cgc hi flowed series 2 r33 turbo soonish
Unless i get off my P's before then, and can get a GTR
S1 is definitely still worth it
easy to tell the different compressors, one is aluminium and the other is nylon. they feel much different
and the number on the comp cover is different
i think the S2 has 45v4 and S1 has 45v3
may need someone to confirm, thats just going by my crappy memory :D
Edited by salad
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
