Congrats on your awesome stand guys and winning a trophy!
BTW Ash...Don't stress to hard, i don't think Shelby is scared for life :)
And since this was my car's first show, its still freaking me out to see how many ppl took pics of her...they're plastered all over the net lol weird.....
Edited by DVSMUM
  • Replies 199
Posted Images
Joel wants to do a photo shoot at Deca for this magazine feature he's putting together, thats the only reason.
I was thinking last night that there are plenty of pics of the car so maybe we could just photoshop me into the picture for the purpose of the article.
I am going to ask uniquecarsales.com.au for some more cash to keep the unique carsales on the car but everything else can now come off. The Yokohama will stay on too.
I can't wait to have it back to normal, I'm really sick of not being able to drive it anywhere.
Just some highlights from my photos taken.
A lot of my shots came out really dark, just crappy lighting or the flash wasnt doing its thing, or maybe drunk operator. anyhoo
The rest of the pics are here: http://paulr33.skylinesaustralia.com/photo...006/page_01.htm
Congrats to everyone who participated and those who volunteered their time to help out where they could.
I had a ball as usual. Buggered but fun none the less.
In the end, the dyno awards went to:
CDUKTV - Toyota Supra - 742rwkw
RH9 - R34 Skyline GTR - 662awkw
Benny's 180sx - 481 rwkw
CDUKTV and RH9 will most likely be at Final Battle along with the current record holder which is a Supra built by Millenium Motorsport in Brisbane which made 748rwkw on the gas to compete for the grand trophy.
It was only 18 months ago that 604awkw was the record. How times change...
Also congrats to SAU-VIC who scored a runner up trophy in one of the club categories.
Phew, i was gonna change my mind at the last minute and paint my 33 same colour, ive already "copied" your kit luckily i didnt do the same with the paint!! :)
Your car used to be silver yeah?
MissyK, is your car the RX8 with the EZZY plates? Any relation to the Astina?
Man i loved that car back in the day!
My rx8 is the red 1 with MISSSK.
EZZY plates on the orangy RX8 belongs to Ezzy Astina's owner :O
Yep yep, hes my best mate. He couldnt make it this weekend, hes back in Syd, so I had fun with his car. His astina still exists... in bits and pieces in his garage :)
MissyK owned the red RX8 next to the EZZY RX8. The EZZY car is owned by a good friend of hers.
And yea, the same EZZY as with the astina back in the day.
sorry John, just saw ur reply lol
Ezzy nowadays is my 'advisor' hahahhaha
In remembrance of EZZY ASTINA, we put the EZZY plates on the 8 :)
Thanks to all involved for a superb weekend. Ash for organising along with Paul for his help also. Scott for the sign boards (that I am happy to spell check for you next time mate :))
All in, a great weekend with lots of laughs and Brisby as usual being the icing on the cake :)
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
