Was up at race solutions this afternoon checked out your car very nice looks comfey inside . I thought the bubble on the back of the roof was a brake light till Matt said it was an aerial maybe I should get onea them for mine look good
Cheers Peter
  • Replies 147
Posted Images
I don't know didn't ask the question ,tried to look after you gave em a little job and said its got priorty over everything somehow I dont think he beleived me :blink:
Cheers Peter
Haltech are making a 20B loom for their E11V2 ECU - also doing some software changes to accomodate the Cosmo ignition system. Using my car to test everything..
All that should be done now - so we should be getting into the good bits soon. I haven't spoken to Matt for a few days - but I know Maroun is chanting at the bit to get started (and so am I).
More soon ......
226rwhp is the baseline.
Which is shit - OEM ECU is crap and running hell rich.
Next milestone is the new ECU with the stock setup - Hitman (matt) is uber confindent that we will get MUCH more power and economy, just with the ECU replacement.
Haltech are still working on ignition code and should be finished monday or tuesday - So that is the next dyno run.
After that - Compression check, full service and all the good bits go on.
More to come.......
More to come.......
this is before the t04 is fitted yeah?
YES mate - it's all still stock as a rock - they are getting the ECU right first - then fitting the good bits.
So the order of things goes like this:
1) Dyno run as I dropped it off to them - 226RWHP - Completed.
2) Install & tune the Haltech E11V2 ( so they can get a basemap for Haltech, so they can sell to other Cosmo owners whio just want the ECU changed) - Not completed
3) Dyno with just ECU and stock everything else. Not Completed
4) Fit the good bits (1600cc inj's, TO4Z, Fuel Pump, etc) - Not Complete
5) Tune with new bits - Not Complete
6) Dyno the final product - Not Complete.
So far we are between step 1 and 2
yay :)
i just assumed that as its been there a few weeks already they would have dyno'd it before now hence my confusion...
but coolio
cant wait for updates :)
Jimbo
Haltech have finalised the new code for ignition - a bit tricky the way it had to be done.
260 HP at the wheels with just the Haltech - standard boost 11.5:1 accross the board.
Engine is a little bit low on compression - but nothing to stop the next stage.
Stay tuned.
  • 1 month later...
Since engine was low on compression and I didn't want to risk anything - Have decided to go with a full race prep engine rebuild - which is why this is taking so long.
Fully Dowled block
Mild Ext. Port
Race seals and spring
The whole shebang
then all the good stuff goes on
Should be ready end of Jan.
Yeah Pete,
They were gone a long time ago - all three std cats have been given the boot. Actually the whole std exhaust has gooooone - Have a nice brand new shiny 3" -> 2 x 2.5" system with one big i flow cat. no resonator and two cannons at the rear - Zorst is FREE FLOW man
Fully Dowled block
Mild Ext. Port
The whole shebang
Good.. told you not to bother with an unopened motor :)
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
