Hi all I have been looking at some R34 GTT and some people have been telling me that its hard to pull out power from this car, I was wondering for those who have R34 whether this is true. I would gather that the car is slightly heavier than a R33 GTST, but what do guyz reckon
Thanks in Advance
https://www.sau.com.au/forums/topic/141792-r34-gt-t/
I dont see how it would be any different than extracting more power from a 33. The 34 gtt has a slightly bigger cooler and slightly less restrictive exhaust, hence doing a cooler and exhuast to it will reap slightly less results than in a 33 gtst. But then again you have more power and torque to begin with...
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2641798
Thanks in Advance
Those ppl that are telling u this...have any of the driven or owned a 34 gtt?
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2641805
$4200 and you will have around 230-250rwkw
FMIC $400 (any cheapy copy)
Turbo Back Exhaust $1000
Slide Turbo $900
Power FC $1000
EBC $400
Fuel Pump $200
FPR $200
Pod Air Filter $100
* Above prices are rough estimates; obviously prices fluctuate and change depending on when you get it and what you get.
It's not hard to draw power from the R34GTT; most of the members here have done the pioneering "research" into what works and what doesn't so all you have to do is read and fork out the cash.
NOTE:
* Auto R34GTTs are a complete headache to modify; I've spent a tonne of hours and dollars going around in circles trying to make things work (yes, one of the pioneers here). So even though you might save a few thousand on the cost of the car; you definitely won't keep that in your wallet for long once you start modifying :happy:
* Manual R34GTT; just follow the conventional methods of modification to any turbocharged car (except for the Cam gears, they do nothing)
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2645109
NOTE:
Just wondering stan.. besides not being able to run a PowerFC on an auto GTT - why is it so difficult?
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2645118
Thanks in Advance
lol mate were they wogs driving VLs?
theres so many members on here who have turned their stock 34 into a monster with some simple mods....
34s aint JUST a bigger cooler and a less restrictive exhuast....the engine....compared to a r33 is also better. being a new NEO version of the RB25DET it has alot more advantages over the 33.
aside from all that im sure theres also alot more
i watched a import mag dvd where it showed a r34 gtt being dynoed and it gained an extra 10kws from a turbo back exhaust. increasing the boost to .85 bar gave the rear wheels 200kws
i dunno maybe dats jsut me but i think dats pretty easy.
Edited by anDru
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2645135
Well you answered your own question didn't you Howie :happy: 1) It's auto, weak gearbox that will blow up on you if you don't do something about it. 2) The auto zaps a fair amount of power from what you are making and 3) the auto ECU is both a masterpiece and a freak of programming nature.
Sure you can stick with your SAFCs etc but soon you'll realize it just isn't enough. 3 options: 1) HKS F-CON V Pro, 2) PowerPlay Rom Tune and 3) Greddy E-Manage Systems
aside from all that im sure theres also alot simple
R34GTT also has a bigger turbo - most of you have forgotten this one which is the main reason for the power difference.
Other things different; the brakes, the suspension, the HICAS system, electronics, NCVS etc etc.
Companies don't release a new variant of a car to make it take steps backwards; they release them to show what new and IMPROVED things they've done to it.
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2645161
i dunno man....ive been hearing alot about mitsubishi and their evos.......
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2645170
Thanks stan that's what i pretty much though as well. So say i'm just chasing 200rwkw i'd be alright with the tiptronic? I just like the auto cuz i'm a lazy bugger these days :happy:
You'll be fine :happy:
Try telling that to the race team accross the road from us...
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2645211
i was told by a 33 owner at dyno day my 34 was putting out the same power as his 33. we had the same mods ,the only difference was he had a power fc and i didn't. i was also hitting r & r. all depends on how much money you throw at it.
him having a powerfc and yours not having one (and hitting r&r) is a pretty big difference in my opinion.
If you put a powerfc on yours (assuming its manual) the gap would open up a fair bit I'd imagine.
Simple fact is, you can get power out of a 33 or 34. They're both very well built and can handle much more than they came out the factory with... :)
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2646072
I never said they were JUST a bigger cooler an exhaust, i was merely giving an example such as doing an exhaust mod on a 34 compared with a 33...
Any one who thinks it would be hard to extract power from a 34 would have to be nuts
https://www.sau.com.au/forums/topic/141792-r34-gt-t/#findComment-2647118
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
