  • Replies 283
If thats the case then i dont suppose they'd know the combination of intake/exhaust housing, bush/ball bearing, water/oil lines and various other bits and bobs.
Garrett do know but have a contract with HKS that they make alot of money from. Business is business.
The HKS turbos allow you to make more power from a simple bolt-on upgrade than the equivalent Garrett bolt-on turbo. Garrett do make turbos that will out perform the HKS turbos but these will not be quite so easy to fit. :dump:
If you have the coin, then KKK & Garret are two turbo brands that i know are used in European racing categories, can someone say titanium turbines! :) (Dont the later EVOs also use titanium wheels?)
Id love to have access to certain workshops and their turbo technology. I wouldnt be expecting huge numbers or boost levels, but awesome response. It pays to remember that most forms of motorsport have boost limits well under 1.2bar. :P
Hi Guys, this is an interesting thread. Let me post some things I know from my experience, not hearsay or rumour, what I have seen with my own eyes.
I have never seen a KKK ball bearing turbo, they have all been plain bearing. Blitz turbos are rebadged KKK's.
I have never seen a Trust ball bearing turbo, they have all been plain bearing. Trust turbos are rebadged Mitsubishi's. I don't ever/will never use plain bearing non-watercooled turbos.
I have never seen an Apexi plain bearing turbo, they have all been ball bearing. Apexi turbos are rebadged IHI's.
I prefer Garrett turbos because they provide compressor maps and I can therefore easily match them to my requirements. HKS don't provide compressor maps and I refuse to guess as to whether they will suite my requirements or not. BTW Apexi, Blitz and Trust don't provide compressor maps either.
HKS say that their turbos are designed to work efficiently at over 1.5 bar. I never run more than 1.3 bar in my engines, there is simply no need. I can match the Garrett compressor airflow to make all the power at that boost level I need. I know that airflow makes power, boost is merely a measurement of resistance to airflow.
So much for what I know, now it's time for some speculation......
Why don't they publish compressor maps? They obviously have them. They say it is to keep their secrets. I say that's a load of BS. If I wanted to copy someone's turbo, I would simply buy one and take it apart. The compressor map tells me WHAT the turbo is doing not WHY, and that is what I would need to know to copy it.
Or is it that they are afraid that compressor maps will empower us to compare the airflow? Heaven forbid we might find out that we are paying twice as much for a 5% difference.
While I am having a whinge, I am not impressed with the magazines that continue to avoid answering this question. They have the resources to do it, have scouted the edges a couple of times. But they haven't gone and done a true back to back, same size turbo comparison from different manufacturers or rebadgers. It is something their readers want to know, but maybe their advertisers don't. Next time you are sending an email off to Zoom, HPI, Fast Fours, Speed etc why don't you ask them.
My 20 cents worth.
I don't know if this has been stated before cause I ran out of patience reading through some of the crap...
Garrett make turbo's for HKS to their specifications, alot of the time based mainly on high performance applications and requirements. HKS and Garrett SHARE info re turbo charger technology, and an agreement is in place that they do not produce too similar products. That is they may have the same code yet different boost and response curves etc...
Now HKS also do alot of TESTING for such large manufacturers such as nissan on the s15 and other models...while Garrett at the same time is the SUPPLIER...
At the end of the day you get what you pay for, and you have to research everything to get what you Need/Want...if you don't want to pay that much for a turbo then DON'T...
However, i would like to see a 3040 comparison as their specs are VERY close to one another...from what people can determine from dismantling the bloody things...
Oh and for the record I would prefer to get a Garrett, however a comparitive Garrett to an RS-R I am yet to locate...any info??? :P
Hi Steve, you asked Bigblockr31, "which turbos to garrett make that outperform HKS?"
Sorry to butt in, but I just can't resist. I have back to backed a HKS GT2540 and a Garrett GT25R. At 1.3 bar the 25R had more power at every RPM point than the 2540. No surprise there, HKS say more efficient at higher boost levels. So I turned the boost up to 1.5 bar on the 2540 and the engine started to detonate. Consequently I backed off the timing and added a bit of fuel to stop the pre-ignition. And guess what? As a result the 2540 made less power at 1.5 bar than the 25R did at 1.3 bar.
Want to get into boost at RPM's? The 25R made boost (ie; the vacuum gauge went positive) some 1,500 rpm earlier than the 2540.
So I can confidently say that on that particular engine, the 25R out performed the 2540 in every way. At $2,700 retail brand new, that made the 25R less than half the retail of a new 2540.
As BobJones so eloquently put it "At the end of the day you get what you pay for", pay less and get more, sounds like a good deal to me.
No challenge there sydneykid, I think everyone knows, including HKS that the 2540 wasnt their best peice of work - it is one turbo I definately wouldnt pay for.
I am a bit confused though how you think it costs twice as much for a HKS than a garrett. You can pick up a HKS 2835 for 3.5K new with new hks wastegate, and that is from an australian shop (just not bd4s or gcg). And from memory (not 100%) a new HKS 2530 is similar in price too, with adaptors for oil and water lines.
Whilst i would think that Garrett and their derivatives are technically better with their water cooling and ball bearing cores, you cant deny that the Europeans make some tasty turbo cars as well.
The GT2 Porsche and racing Porsches, the flurry of supercars out of the VW factory badged as Bugatti etc, also Audi all using KKK turbos.
Whats the reason companies like VW, Porsche, Renault are not using ball bearing turbos, that arent water cooled, in road cars and motorsport?
To the best of my knowledge the only European turbo powered sports car and/or their racing derivative using Garret turbos is Lotus (???)
Just raising a few observations of mine...im only going on what i have read in magazines like Racecar Engineering.
...and i believe the Apexi turbo on a 180SX an old school friend owns is bush bearing and isnt water cooler, how recently did Apexi start using the BB IHI turbos. (IHI are the makers of the VF23 etc STI turbos are they not?)
Hi Steve, I always quote the manufacturers (or their agents) recommended retail prices. Using trade prices, discounts, specials, end of model run out, mates rates etc just confuses the matter.
Plus, in my example, the 25R fitted straight up to all the standard pipework, exhaust, heat shields ducting etc. The 2540 didn't, so it needed compressor inlet adaptors, modified heat shielding, compressor outlet fabrication, and I had to change all the water and oil pipework over to the HKS parts. Included was the fact that I had to pay extra for a 1 bar wastegate actuator and gaskets that the 25R came standard with. Hence my "double the price" comment.
Hope that clarifies
Sydneykid, the prices I quoted isnt mates rates, discounts, etc
And as I said, 3.5K for 2530 with bits needed to fit RB, including wastegate actuator. Must qualify, I am not 100% this is exact price, but I am pretty sure it is very close if not what they can be had for, if you buy from the right place.
I agree that HKS are more expensive than garrett, but its a price I am more than willing to pay, for the extra. It costs alot of money just to milk a few extra kw out of a car once you start pushing things a bit, so IMHO, its money well spent.
Bottom line is, what exactly are you after - if you are happy to pay a bit less, and perhaps not get the same performance, fine, nothing wrong with that. Personally, I dont mind paying a bit more (definately not twice as much) for something as important as a turbo - its the heart of a turbocharged car.
Hi Steve, I am not rubbing anyones' nose in anything, OK? But this is the recommended price list from HKS Australia for 2540's.
GT2540 $4312 350 46 51.7 76.2 60 50 0.60 76 53.8 47.0 T3 Internal - Skyline Type 0.64
GT2540R $4356 360 46 51.7 76.2 60 50 0.50 76 53.8 47.0 GT25 Internal - GT25 0.64
Check it out for your self at www.hks.com.au
While you are there you should have a look at the picture of the GT2540R, it has no HKS on the compressor cover, only Garrett.
Thats the problem, some would say beauty (those chasing big numbers) is that a 300hp turbo with internal gate does not cost half as much as a 600hp external gate turbo.
And its not realy fair to expect BD4s to cpmpete price wise. They have workshop/mechanics/insurances/taxes etc costed into their prices vs a bloke operating from home (perhaps even after hours as a 2nd job) over the internet with a lot lower overheads, which sometimes doesnt even attract all the taxes it is subject to when sold by an OZ workshop.
INASNT, thats ok, I got a new HKS 3037 for not much more than $2500:p
The thing is that you can get a not so pissy 2835 for similar price, or 3037 - as Roy pointed out, you dont pay alot more for a larger turbo.
I think even a GCG highflow is what $2400 exchange, with the current going rate on a good second hand RB25 turbo, thats nearly 3K for a highflow.
Common guys, throwing prices around like this is not fair, I got a GT35R (rebuildable core) brand new for $1600. Nah Nah Nah Nah, mine is bigger, stronger, upgradeable, repairable and costs less than yours!
So what?
There is only one way to compare the cost of things and that is the manufacture's (or their agent's) recommended retail price, anything else is not repeatable or sustainable over any period of time.
Bottom line, I would have a 25R over a 2540 every time, even if they cost the same. Which they don't. I'll do a bit of digging through the old files and see if I can find another HKS bashing comparison. I am sure there is at least one more, I just have to find it.
As I said before, this is a fun thread.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
