hey guys
did a search but cant find many actual answers with proven results. everyone says 'yes my exhaust is quiet' but havent actually had it tested.
just got off the phone to a tester who claimed that no 3" system will be under 90db. can anyone prove him wrong? ive got a 3" split dump to a wide body hiflo cat, 3" cat back system with a hotdog muffler and jazma oval muffler. he claims it will be over 100db.
what have you guys got.
https://www.sau.com.au/forums/topic/142024-how-loud-is-your-exhaust/
  • Replies 55
my system is pretty loud, was a peII but took the centre part out and got a custom 3" straight pipe made for it or the same diameter. So i got a 3" dump big body cat and straight pipe to the rear >_<
My old 80mm catback with proper mid muffler and enormous rear muffler came in at 92dB at 4k. This was with a 3inch dump/front pipe and regular old ceramic 3 inch cat and highflow turbo.
I reckon the stock turbo would have dropped it a touch more as there was a noticable increase in exhaust noise after i went highflow
yeah would be hard to find a 3 inch that'll make it under 90db
mine used to be 115, but that system was rediculous...
stop livin in the past man !!!!!
how do you measure the db's anyway? i havent got a db meter.
CES dump pipes and 4 in straight thru no mufflers at all (track only car so no Cat) its fkn loud
Hang on is that a dB tester up my ass...when i extract it Ill get a reading
Edited by gtr660hp
3inch all way, as quiet as my wifes 'frontal' wet-farts
:):P:O
farken hell, did ya have to ??? huh? damn :O
i just put a 3" highflow cat on my turbo back 3" exhaust (mild steel, mandrel bend). and the fuccker is now slightly louder, but also very droney. i cant stand the drone. dont like the drone. would like the drone gone.
will a resonator return it back to the nice throaty note it had when running a 2.5" standard cat?
My friend has a db tested thing. Same as the exhaust place uses. He tested my exhaust at 108 db from memory. Then i made up this thing to go just after the cat. Just got a bit of tin cost me $1.75 from bunnings. Cut it to the size of the gaskit. drilled some holes in it and put in in the exhaust. Got may mate to test it again and it was 92db. The exhaust shop tested it at 86db.
Removed it after the test. I have a 3" system.
Mine was 86db at 800rpm... Went do 105db at 4000rpm or something stupid. Thats 3inch from the dump pipe back (stock dump). Just the cat and a cannon.
Then I got two big arse mufflers put on 84db at 4000rpm. Still 3 inch. Its just so much better, I can now hear my stereo on the highway.
the trust pe2 is def below the legal limit of 92db - it produces a very slight howl between the 3k and 5k range - but compared to the blitz nur spec its almost like a standard exhaust.... I think someone said its at 88db or there abouts
The legal limit is 90dB for passenger cars according to the information available from the official ADR website:
http://www.dotars.gov.au/roads/motor/design/adr_online.aspx
in particular, ADR 28 is what I'm referring to.
Note that ADR 83 apparently supercedes 28; but ADR 83 has plainly been written by someone who was smoking
some kind of illicit substance at the time (it's full of conditions like "if it's the second tuesday in the month after 2pm
but NOT in a full moon, subtract 1dB UNLESS the car is owned by an Amish vegetable farmer in which case add
1dB ENSURING that the summer solstice is observed"). I had a quick browse through 83 and I was unable to
determine what the noise limit for my car within 30 secs; ADR28 allows ready lookup so plainly our pollies
are doing their jobs of making things even more incomprehensible.
Idiots.
edit: T04Z, HKS 50mm gate, 4" stainless exh, 6" cat, 6" resonator, large muffler w/ steel wool:
85dB with restrictor fitted and closed
89dB with restrictor fitted and opened
93dB with no restrictor
97dB with small 6" rear muffler
Any exhaust place with a dB meter can measure; the measurement procedure is defined in the ADR.
The meter is supposed to be calibrated regularly too.
Regards,
Saliya
Edited by saliya
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
