I remember they had a few parts...
Or can someone recommend a place i can get one? The bodykit goes in for paint on the 20th, will be there for a week. So i need to have one by abouts then!
Whats the best avenue? im going to do a search for STAGEA in the traders forums too, but any help would be appreciated.
cheers
https://www.sau.com.au/forums/topic/142074-aero-style-front-grille/
Not sure what type you are after, but you could try Zac at Slidewize. Expect to pay around $200 delivered, and you should receive it within 2 weeks.
I bought a grille off a non turbo (I think), but it goes well with the Nismo kit, if you like I can send you a pic.
There's a link to grilles here, http://www.slidewizeimports.com/products/y...inksStagea.html
Cheers
Daniel
  • 4 months later...
Just to dig up an old thread. I'm picking up my body kit this week and would also like the mesh style (like the dolphin one) and a set of eye lids to go with it just to set it off. I know I could go through Slidewize and import some but if any one knows anywhere here is Aus that I can get them from that would be great.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
