Hi Guys,
WINNING BID $250.00 - Kel - WELL DONE TO ALL BIDDERS AND THANKS FOR YOUR SUPPORT! :(
The bra is back up for auction as the user 'maccattack' has kindly re-donated it to a more than worthy cause. Lets get the bidding going again - it stands at only $5 at the moment so chip in and do your part!!
DiRT Garage (in particular, Racer Stace) have offered for auction this one of a kind bra to raise money for breast cancer research and prevention. The bra is decorated with silver sequins, silver racing tassles, a racing flag, a Racer Stace Badge, drag racing start tree and a R34 V spec N1.... lined up, ready to race on a velvet ribbon track. (see pic attached).
All monies raised will be donated to the Breast Cancer Research Foundation. http://www.nbcf.org.au/ - https://4tknox.au.com/nbcf.org.au/new/donate.php
Come on guys'n'girls - kick in and raise some dosh for a worthwhile cause.
Cheers,
Adrian
  • Replies 42
Posted Images
What size is it? :wave:
Bit hard to tell as i dont know the model, although i have my suspicions it could be you Adrian :)
Just wondering if it will be a snug fit or not you see :sorcerer:
good to see ppl are willing to give money for a good cause ! i'd love to bid but im completely broke :( might see if i can buy a daffodil pin or something from the shops then.
This item has a bit of a story behind it...it was handmade by Stacey for breast cancer awareness week and was entered in a competition which was won by a tacky little piece with stuck on plastic flowers on it (how original).
So she thought it would be too good to go to waste, and what better place to auction it off than here.
Those of you that don't know Stacey might not be aware that she is the fastest and quickest female ANDRA sport compact racer in Australia, so this is the ultimate clothing item from the fastest chick skyline pilot in OZ.
Happy bidding
Should get it signed too then. :)
And also when does bidding finish?
bidding shall close at the end of the month 30th Nov at midnight. So the last highest bid registered here before that time is sucessful.
In order for people to know what the current bid is on, without reading all the posts, i suggest maybe updating your first post with the current highest bid :thumbsup:
Fantastic idea guys/girls, my mum just had surgury this time last week, and is about to start the rest of the looooong process, Unfortunatly i'm strapped for cash ATM but will report back later in the month!!
Well done people!
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
