  • Replies 77
Posted Images
LOL that is funnnny!
I think loose it. Because really what kind of quality are you going to get out of it, its a race car... so no sound deadening = no sound quality, noisy exaust and all that crap, so once again you wont hear it properly...
There is plenty of sound deadening and the exhaust isn't noisy.
Na keep the stereo....use your choice of tunes as strategy and phsyc out the other racers :)
seriously though, Is a couple of kilos going to effect a sedan? If it was a fuel car etc maybe a couple of kilos would be worth it. On the issue of personnel stereos that use ear buds they are proven to damage you hearing if turned up too loud :)
I hadn't thought of F&F tunes :)
I must admit, one of the coolest cars i've seen at WSID was a red WRX with a big stereo that ran respectable times then cruised down the return road as loud as the in-house P.A. !!!
....a big stereo that ran respectable times then cruised down the return road as loud as the in-house P.A. !!!
Exactly, I enjoy cruisng into the staging lanes with the full exhaust and the stereo on then blowing away the commodores etc with the open exhaust and monster tachs. Take that old skool small block :)
If you watch Getaway in stolkholm you'll know about the ITSFUN Porsche, that's a race car with a stezza. They just gave it a huge overhall, and it's still got the stezza in it. Search google for itsfun3
http://www.zatzy.com/showthread.php?t=234429 thread on the rebuild.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
