hey ppls
for the last few months when my cars idling on a cold start it sits at like 600rpm.. if you start to drive or just touch the throttle it revs fine but then drops to about 300-400 then back to 600. after about 2 mins when the temp gauge has moved up about half a cm its fine and the revs sit on 750rpm or so and dont bounce around.
hmm come to think of it when the car is cold shouldnt it sit on like 1000-1200rpm or something higher like that ? anyways i had the bouncing idle problem (but when the car was warm, not cold) a while ago and i cleaned the aac valve and that fixed that up, but im not to sure what to try clean now.. ? I was searching and theres some cold start valve or something ?? where abouts is that ?? is that the same as the air regulator ?? i had a look in the workshop manual, i couldnt see it on my actual car though.. anyone got any pics or any other ideas what it might be ??
thanks :whistling:
https://www.sau.com.au/forums/topic/142270-revs-bounce-on-cold-start/
i started the car just now to have a look. I drove about an hour ago so the car is still hot, but the needle is about 0.8cm above the bottom and the pfc rekons its about 63degrees. The middle which it always sits on after about 5 mins of driving is about 84..85 degrees so i think thats working fine like it always has.
but ya the idle is fine now cause the car is already warmed up a little bit..
Have you had the PFC programmed / tuned for "cold start"? Maybe it needs a bit more fuel or timing when it's cold.
BTW, I don't see anything in your initial post that mentions you have a PFC - such information would be most useful.
I've got the same sorta problem, wheres acc valve, u said before...
"a while ago and i cleaned the aac valve and that fixed that up"?
I also have the pfc but even when my car warms up i still got the problem not really bouncing but drops low and sometimes stalls, but if i ease the clutch in its ok as apose to "stomping it in" when im rolling up to lights, driveways etc but the revs are sometimes ok and sometimes low...
ya i found the little barstard the other day.. looks impossible to get out though, all i can see is like 1 bolt :P
it could be the iac valve. the aac valve is what always gets cleaned. the iac is down under the intake plenum. (i think thats why not many people clean it) from what i know of it, it controls the idle air for cold start.
Yeah does sound like AAC Valve, it bleeds more air into the secondary air system to bring up the revs when cold. Have to get it apart and clean it out. Also inspect the tension of the spring.
You can't (and don't need to) clean the IAC (Cold Start Air) valve. It is not operated by a servo-motor, as the AAC (Auxilliary Air Control) valve is. It is a simple bi-metallic strip, heated by electric current - as it warms up, it causes a plate to cover the air bleed hole.
If it has any sort of problem, it may be that it is not fully uncovering the hole when it cools.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
