Hey Guys, thought to share this with you... i just installed an R34 GTT SMIC onto my R33 GTST and boosted to 10psi + ECU Reset
Current Mods: 3" Split dump + 5" S/Steel CAT + 3" CAT back exhaust + Turbotech
Results: Car comes onto boost MUCH smoother & revs to redline MUCH easier.. there has been a HUGE increase in pull through out the rev range especially in 1st and 2nd gear... Dyno would be nice, any one offering a free dyno pass? lol
Recommendation: Definitely worth the upgrade if you have stock turbo... Proior to this upgrade, the car felt held back and restricted, now the car feels much freer and has noticably unleashed more power... Throws you right back in the seat :wave:
Note: Prior to the SMIC installation, i flushed it with degreaser/hot soapy water and i couldn't believe the amount of black crap that came out! had to reflush about 4 times before it was 100% clean... then ran warm water though to get rid of the soap/chemical residue... i then stuck an old hair dryer in one end and let it sit there for 30min untill it was drip dry.. worked a treat!
Look at the size difference between R33 SMIC Vs R34 SMIC!
Here is a couple short videos while driving home tonight, its just to show the smoothness of boost and ease of rev... (excuse the bad footage due to holding my phone while recording and driving) Hope you like!
video_0004.mpg
video_0003.mpg
Regards,
Sarkis
Edited by QRI05E
  • Replies 68
Posted Images
OH good work! I've already put the 34GTT cooler in, and the turbotech controller... Got all the exhaust parts, but haven't fitted them.
When that's done, i'll shove it up to 10psi... same as you have. Hopefully it'll feel the same!
Can't play vids though =-/
Edited by RANDY
I wonder if a change from a R34 SMIC on a GTT to a FMIC will show the same benefits
No, you will not mate the R33 and R34 turbos are much the same except for a slightly larger exhaust housing on the R34. So unless you upgrading your turbo keep the stock GTT cooler. Its a good unit and you wont loose any throttle response to that of a large frontmount.
always good to see these cheep mods work.
cheers
I was thinking of doing this upgrade but thought if i do end up wanting bigger power i wouldnt want to do another upgrade to fmic. so im just going to get a big fmic, but good luck with your mods!!
Hey Guys, the video's were recorded in mp4 format and wouldn't upload onto SAU i had to change the file extension to .mpg for it to work... if you guys try and open it into real player they will work.. or download any divx codec pack and will work in windows media player...
Just a reply to Nismo God, i am planning for big power in the future, however until i am financially ready for a larger turbo + rebuild + injectors + fuel pump .etc. the R34 SMIC upgrade will give you the full potential out of the stock turbo and setup... these SMIC's have been known to hold anything up to 14psi and 200 - 230rw/kw which is more then the stock turbo, injectors and fuel pump will ever handle... so in my opinion, full exhaust + boost control + R34 SMIC + PFC will give you the maximum and most reliable tuned power out of a stockish R33... and wont break the bank.. Not to mention will not give you any issues with the boys in blue as a FMIC would :whistling:
Cheers,
Sarkis
Edited by QRI05E
yeah i got it to work.
sounds smooth. hard to tell from that vid though.
your exhaust sounds good. 3" turbo back right? any mufflers in the middle? like a resonator after the cat?
Did not realise there was such a difference in model SMIC's!
You could probably put a thermo fan on the front as well to get a bit more from it as the airflow in there could be a bit restricted. Maybe a water sprayer as well just to complete the efficiency of it all. :happy:
Yep i got a full 3"... Split dump ----> 5" s/steel CAT ----> 3" cat back ------> resonator half way ------> 6" Cannon
I love the sound... its just perfect, not too loud and just enough growl to turn heads and let alarms off heheh it was built for performance not noise... 21rw/kw gain on stock boost nothing else was touched....
I used the R34 SMIC Shroud as induction... had to slightly modify it to fit behind the S2 R33 front bar... After a hard thrash (30 min driving) the turbo side of the SMIC was hot and the manifold side was warm/cool... the stock R33 SMIC was all hot after a thrash... made quite a difference...
You can actually hear the car rev out real easily in the video and see how it pulls in mid range... I can feel the difference when driving...
Regards,
Sarkis
Edited by QRI05E
Hahaha Cubes, i eased it to 4000RPM then gave it a hit... same as the other video... She goes real well compared to many other R33's and R34's that i have raced, some with more mods then mine (EBC, PFC, FMIC) :verymad: hehe
Cheers
Edited by QRI05E
Not quite free but hey.
http://www.skylinesaustralia.com/forums/in...howtopic=140448
Entry fee is $50.00 for three power runs with a printout
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
