  • Replies 56
Originally posted by INASNT
Nark looks good.
I am surprised u actually managed to take the cooler pipes off and bov and replace it without stuffing anything up! :P
Aint u putting new cooler pipes on when u finially put your GTR FMIC on?
u think i wasnt!!! :)
well actually i did... i forgot to tighten up the hose clamp on the pipe from the plenum and was dropping boost pressure :P funny that.
but yeah the engine seems to be running fine now so i dont think ive done any damage :D
munkeh - yeah it is.... reckon the paint would stick?? its heat resistant paint anyway.... maybe i leave it black and paint the screw bits yellow :P
EDIT***
denham - not to sure if im going to bother puting the cooler on now if im going to be getting a GTR next year... might just save my money.
Originally posted by acsplit
well for someone who does not like rice you seem be ricing it to perfection :):P
hmmmm hey andrew, maybe its the paint in my engine bay that makes my (mostly stock) Ti go faster than your GTS :(:) :shake:
When the rice is hidden, it's not so bad. ;)
Nice job inark, looks good!
Photos are never representative of true colours, so I can't wait to see it in the metal!
:D
well.... I went and did some more painting today :D
Painted the cruise control, and brackets, and the air horn compressor and some bits and pieces, dave made a heat shield for the pod, and another one for the extractors, and i painted the pod one white, and the one for the extractors is polished..... mmmmmmmm......... shiny bits......
looks sweet nark.
might have to do something similar, not that wild in the colour though.
nice deep purple or something, if and when i can be bothere that is :)
can't wat to see it actually!
so wat's next? Calipers too LOL
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
