Definitely 0 when not running. Without the oil pump running there is no oil pressure.
Depending on age/condition of your motor and the viscosity of the oil you use, you could see anything up to 7/8 or so when cold, and 4 when warm. The 33 I drive practically every day sits on 4 when cruising on the highway, but my old car used to sit just above 2.
If you're worried, put a second oil pressure guage in to compare readings.
hi all, just wondering if this is normal. I just changed my oil last night but this morning i noticed it was all the way to the top when I first started it, it dropped as the oil heated and sat pretty normal. What is the real concern is that when i give it to it, it rises up past half way getting closer to the top. Im only new to the skyline seen been that i have only had it for 2 months. Is this normal?
Can anyone please confirm if it is normal for the oil pressure to rise as i rev harder...when i accelerate the pressure rises and when i push it harder, ie 4000+, it rises higher getting closer to 8. is this normal?
It should rise as the revs rise......
8 seems high though....
What viscosity oil did you use???
Just changed oil.
i use 5-30 and the gauge reads lower now. Needle sits about 4 when hot and running at revs
the dude at the shop wouldnt let me leave with the oil i wanted...he gave me 20-60...i thought this was wrong but he assured me it was correct. would this be throwing it high? im going to the drags tonight and dont want to blow a head gasket...
i think the oil for stock rb25det is 10-30 or 0-30, not sure if its the same for the non-turbo engines, i just got magnitec 10-30 for mine and its rises with revs and it still runs smoothly (though it doesnt rise up to 8).
Be a bit thick wehn the oil is cold.....
should be fine once warm though......
A 30 grade (hot) oil, ie X-30, is basically designed for the cooler conditions in Japan. Coming summer in Oz, I would think you could probably run a slightly heavier oil, like 10-40. Maybe 20-60 is getting a bit too thick.
gues i wasted $35...damn im going to buy some oil at lunch and go home to do the fastest oil change in history. Oh and when i sell it i can say i change the oil daily....engine care is what im passionate about....i even put in one of those engine tune up things....damn
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
