hey guys i got a 32 gtst and i want to no if they have factory boost controler? because i put a single stange boost controller Turbosmart and it dosent switch boost and my mate said if they have a factory one then they wount move. its set on 12 standard and i put the boost up went around the block and it dident move!!! flicked it hight and low and stayed on 12...it pings to 15 and drops to 12 why is that. can sum1 help me like tonight within the next 10mins im working on it now!! thanks
https://www.sau.com.au/forums/topic/143570-r32-gtst-help/
there's no factory boost controller mate...
what mods do you have?
i'd say your problem is either
- you have no mods and so upping the boost against a restrictive exhaust is doing nothing
- your boost controller is crappy and spikes then doesn't hold boost to the redline
i'd say its the boost controller
also, check to make sure you have it on the right way (there should be an arrow)
good luck,
Warren
https://www.sau.com.au/forums/topic/143570-r32-gtst-help/#findComment-2679381
turbosmart boost controllers are crap. i had a dual stage one for a while then i ditched it for my old turbotoech controller.
have you set the second stage up properly for 15psi?
it could also be that the solenoid is blocked or not switching over in it. mine did that. i'd flick the switch and you could hear it switch but the solenoid was blocked so it wouldn't change boost.
https://www.sau.com.au/forums/topic/143570-r32-gtst-help/#findComment-2680049
What supporting mods do you have?
R32 gtst run standard 10psi so you are pretty close to the limit alreadt for a stock car.
Unless you have a full 3 inch exhaust and intercooler i wouldnt try to increase the boost at all.
https://www.sau.com.au/forums/topic/143570-r32-gtst-help/#findComment-2680176
yer my car sucks.. 2 different motors and i've always required an ebc or other means to hold boost. It always tails off to ~2-2.3psi above actuator pressure.
the turbotech ball/spring mbc's do work better than the usual bleeder. The usual bleeders do tail boost off on int. gates. They appear to work fairly well on ext. gates.
https://www.sau.com.au/forums/topic/143570-r32-gtst-help/#findComment-2681592
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
