  • Replies 167
Posted Images
well - that guy shouldnt have said all that stuff about a trader on the forums - he should have discussed his options or whatever through emails/pm/phone
and he should have also done research that where someone is foolish enough to talk a lot of shit, he/she will be ridiculed like this
Does anyone else see what i see?
And no, im not talking about the lack of spelling
The bits of 9500rpm and 60,000km's stand out like a motor that isn't exactly fresh. :D
BBE or more appropriately BBQ. :P
How is your oil pressure, I don't believe you have answered?
A motor can appear fine when its not.. Guilt Toy's is a prime example, it began playing up 6months before it let go and began knocking.
But in all honestly... if you really have done 60,000km's and been flicking it to 9500rpm quite often its most definitely not going to be anything like a fresh motor. Its going to be worn and may very well have issues you are not aware of.
As the bearings showed signs of dirty oil you may have left a little swarf behind after drilling the oil restrictors out and or it was fitted up then later drilled out when you realised it had to be drilled out.
Is this the case as I believe in a previous post you made mention that you initially didn't know they had to be drilled out as it was a direct bolt on.
Aaron from slide the day i got turbo delivered sent a link explaining oil lines needed modding, in link it says to redrill banjo fittings to 6 mm and banjo oring (end off line to 55 mm ) this was all done as specs showed, even thou i got told originally it was strate bolt on
Never mind if I am wrong its my sceptical nature. :D
Slide has been kind enough to post pics and the report of what was wrong with the turbo... So you now know there was an oil supply problem. Can you possibly think of why there was an oil supply problem? Do you think it may have been the oil lines + a little swarf, engine oil pressure is lacking? Possibly a blocked oil galley turbo feed in the block?
Take the criticism on the chin and forget about it, try to work through with everyone and get to the bottom of what the problem was. It clearly wasn't a fauly turbo as the bearings showed lack of oil.
ive got a question, wouldnt it be right to say if he does it himself he has only himself to blame, hence would also void any type of warranty? what an idiot i mean if it is true 3-4 turbos since far out it would have to be a clear indication.
Meh wingers theres always one that is never happy.
NEXT time why dont you buy a non turbo car, save you some money and hasseling or get a "Professional to do it" no no i dont mean yourself
A
Edited by Devils_Advocate21
If anything this is good publicity for Slide as the public have been shown that he is a reputable and trusted trader.
I plan to get one of his hiflows when I mod my GTST up in the next few months.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
