Items:
hi flow/standard turbo to bolt strate up to r33 manifold
Extra Info:
must be good condition.one that has been reguarly used until basicly when i buy it.dont want any that have been sitting around for months and months.
Contact Details:
pm me.or txt me.4go my number so ill post it l8er on
Price and price conditions:
nothing over 500 for a hi flow etc cheaper for a stock turbo.[im a tite ass]haha
Edited by PRO AERO
Items:
Std r32 suspension
Extra Info:
looking to buy, or borrow, maybe swap with my bilsteins until i clear defect.
Contact Details:
pm, reply in my defected thread, or call me 0405 241 064
I can pick up from anywhere, but u can call me to wrok out the details.
Edited by Bl4cK32
Items:
stock 33 gear knob, or somthing thats not gona get 2 hot, and feels nice on the hand...
Extra Info:
mines got metal bits and it burns when the suns on it 4 a while :ninja:
Contact Details:
pm or mobile 0402 44 88 99 or msn [email protected]
wont sell my arm for one, pick up anywhere....haha
Items:
1 x BNR34 GTR rim
Extra Info:
will consider a pair but would prefer just the one
Contact Details:
PM me with any info
Around $300 without tyres and will consider a rim that would need a respray or even slight welds.
Items:
S13 Silvia SR20DE (Non Turbo) 5speed manual
Extra Info:
Has to be in good condition no rust, scratches, rips, burns dont want anything with really high km's. And DONT want a silvia with the brown interior :/
Contact Details:
PM me
Dont want to spend more than $7500 - $8000 just depends on the condition of the car aswell :ninja:
Items:
Blown (=cheap) R33 or R34 turbo (to hi-flow) - up to $150
R34GTT Rear spoiler - up to $200
R34GTT stock front bumper bar lower lip - up to $200
Contact Details:
PM/email me
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
