Items:
R32 GTS-t Front Left Wheel Arch Guard - Black
R32 GTS-t Rear bootlid - Black with NO holes in it (dont know if this is possible at all!!)
R32 GTS-t centre and front left air vents (haha yeh im dreamin, but in case someone hasnt sold them already)
Extra Info:
Trying to make the car look a bit prettier
Contact Details:
Contact me via PM please :)
Price and price conditions:
Let me know if you have a specific price, if not we can work to what suits both parties!!
Thanks
Laine
Items Wanted:
R33 series 2 BOV - stock one or aftermarket plumback
Extra Info: must be able to bolt on to my R33 GTS-T 98
Contact Details:
email: [email protected]
looking for one under $200 and will pay for postage.
Items:
Z32 Airflow Meter
Extra Info:
New or Used
Contact Details:
Contact me via PM as i am on here every day
New $250 or Under
Used around the $150 - $200 mark
I might be dreaming but i am hopeing the someone has one they do not need!!!
Cheers
Shaun
Items:
WTB...ke70 corolla must be manual,decent condition and have rego
mr30 skyline sedan,must be manual and in good condition
r31 pintara or skyline. . .manual or auto considred once again in decent condition
Extra Info:
just need a CHEAP run about as my skyline is a fair way off hitting the roads
Contact Details:
pm me or 0400260352
as cheap as possible but depends on condition of the car
Items:
18 inch wheels and tyre to suit 33
Prefer something with a dish but open to offers, so if anyone is thinken about selling there wheels, sing out no matter what they are. Have cash waiting, tax time lol.
Contact Details:
PM me
[email protected]
Depends on wheels and tyres
Item:
R32 manual, good condition
180sx manual, good condition
Extra Info:
must be manual and be in good condition. dont mind about mods.
Contact Details:
PM me or Ring 0423002689
depends on condition. looking to spend round 8-13k
Item:
The following R32 GTST items:
Complete stock airbox with intake
Good Condition late front seats
Front metal bar that goes behind front bumper
Contact Details:
PM me
Don't want my pants pulled down over the price but will pay what worth in cash.
Edited by Xpeccen
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
