r33 GTS-T stock suspension, shocks and springs. If you got a set pm me quick or will go out and get a brand new set.
must be good working order, no leaks, not bent etc...
bought a set already, thanks Tommmo
Hey guys, im after a set of r32 4 door weathershields/ window shields for the doors.
They generally come in a tinted/ clear colour but let me know what you got.
If you have some spare or you want to get rid of the ones youve got, let me know
Or alternately if you know somewhere that has some, let me know.
Located in Adelaide, SA, but if anyone interstate has some i'd be more than happy to pay postage.
Cheers.
Example pic (strips along the tops of the door windows)
Items:
TO SUIT A R32 GTS-T 2 DR COUPE
HALF OR FULL ROLL CAGE
FRONT/REAR STRUT BRACES
RIMZ FROM 16" TO 18"
HYDRAULIC DRIFT HANDBREAK
RB20DET MODS
Extra Info:
NEED THESE FOR CURRENT PROJECT PREFER DECENT CONDITION ITEMS.
Contact Details:
PLEASE PM ME IF U HAVE ITEMS AND ILL LET U KNOW WITH PRICES AND LOCATION, PICS CAN BE SENT TO 0402217466 IF REQUIRED.
Price and price conditions:\
TAKING OFFERS OF PARTS AND CASH PRICES ATM.
WILL SWAP PARTS LIKE, FRONT/REAR GTS-T M SEATS AND REAR PILLAR COVERS,AND STOCK REAR BAR FO RSMALLER ITEMS.
Needing 32 or 33 clutch fan. Please contact me on 0430 362 050
Thanx heaps
Radiator workshops can often recondition clutch fans by opening them up and replacing the silicon fluid on the inside. (I have had this done with a Toyota thats notorious for faulty clutch fans)
