want to borrow:
Girl, must be hot and good in bed. 18-26, attractive.
Pm me with offers
ah the old can i borrow you. only for an hour or so. but can you make sure the dishes are done by the time you leave. thanx :devil:
Im after a 3' Bellmouth Front/dump pipe for my s1 stagea (rb25)
ive got a bellmouth/dump/frontpipe off my r33 sitting at home made by boostworx
only problem is it was made for a highmount set up, but you prob get them to cut a section out and weld them both back together to make it shorter
the dump flange is for a standard rb25 turbo
$30
Edited by ovrtym33
$30
I think by the time I buy yours get them to mod it to a standard mount turbo it will be more than the $200 odd dollars it will cost me to buy a new one :(
$30
Got a pic of it? If its a high mount, won't the ex housing be rotated in the wrong position for a low mount turbo? Interested.
On that note ...
WTB split dump pipe or similar for RB25DET to replace stock dump pipe.
On that note ...
Can't edit, so here's a pic of what I'm after.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
