Items:
R33 M-Spec Front Bar S1
Extra Info:
White, Half decent paint job, if not still let me know what it looks like
Contact Details:
PM me
Price and price conditions:
Let me know that your after and we can work out a deal
Need an RB20 silvertop ECU asap, no loom, just the box, I won't be checking this thread so could you please call me on <removed> or PM me with price that would be amazing. Also need a nistune for it, I am planning on getting this separately but if you have the lot that would be even better.
Thanks guys :cool:
How much was it to get your system made up? I am tempted to get a stainless catback made up, i got stainless front pipes on now. That sounds mental though I love it.
Edited by Weezy
i paid a bit under 1000 for a split dump highflow cat and custom twin system
should of been closer to $1200 Andrew really looked after me (Heslo can vouch for being well looked after as can Dave even with a few drama's)
steel was Australian stainless not Chinese rubbish
I might have to hit him up for a stainless cat back as I've already got the front pipes. I'll see how I go :rant: Few other important things right now I want to take care of with the car and the exhaust as is, is okay.
I'm thinking going 3.5" catback, whats everyone else think?
