Found this on ebay:
http://cgi.ebay.com.au/51MM-UNIVERSAL-SING...=item5d27c3456d
might be what you are looking for... :(
wondering it anyone has a spare ash tray thingo, the thing thats under the cd player (not the actual ashtray, the bigger compartment).. the thing where you hide your turbo timer.
need one, silly me cut mine and chucked it when i got the 3 gauge cluster thing.
Would anyone be interested in a swap Nokia White n97 for an iphone? I thought i would like the nokia but don't use it as much as it could be if the right person had it. Only had it for 3 months screen cover is still on and no scratches on case. Just thought i would put the idea out cos you never know :-)
PM if interested.
Cheers Mel
I'm after a full set of cefiro/s13 coilovers.
PM me with what you've got.
Chad mate,
Ring up Sinergy Motorsports, because your car is just a track cop they have Japanese coilovers there that knock but don't leak for really cheap which would be ideal for a skid car imo.
Goodluck.
I've got a mate looking to buy a Stagea.
Must be around $10k with as low as possible KMs
Mine's got quite low kms ... but I'd want far more than $10K. :ermm:
Coulda had my silver RS4 for $10K a while back ... but thats long gone now.
Lowest dealer price I've seen is $13K for series 1 with 46,000kms reduced from $17K
Lowest private price I've seen is $11K for series 1 on ebay with undisclosed kms
Your mate might need to spend a bit more.
I know GRIM (Ben) is looking at selling a few Stageas ... including a white 260RS ... but its got higher kms on it. :)
my rs4 S2 was $10,500 with 75000kms - but in QLD
the P plater laws have caused the prices to fall out the bottom
anyway a set of mags in 17inch have been found and purchased
thanks to all those who helped/offered
Dan
not on the net to often so please call or sms if you can locate parts. looking to remove my current intercooler setup on my 33. currently running a 2.5" piping setup that can be easily manipulated to suit front facing plenum with a big 100-120mm thick cooler i think from memory. will sell when fit a new setup.
but looking for a series 1.5 r33 reo bar and cooler + piping setup to fit without cutting so i can clear regency if it happens without being dicked around (my reo bar is cut open to fit the big cooler....)
and a 33 strut brace of some sort possibly.
and interested some 15-20mm 5x114.3 bolt ons
will purchase on my own or trade my starcorp impuls without tread currently for sale + cash
cheers, ken
0422603195
Edited by kenvv
aftermarket clutch for an rb25det in good working condition (cheaper the better)
looking for standard r33 2 door sidskirts (maroon in colour would be good but doesnt matter)
Edited by Import S13
We'll be getting rid of our White S2 RS4, 95kms, 18" Rays rims, 2 Din JVC DVD and comes with front mount kit not installed.
Should be able to work something out with price.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
