WTB. R32 bodykit preferbly BN and also if its white but jus show me what u got cheers, also willing to swap with stock bars with cash adjustment for your body kit
i got a full kit painted red.. one side skirt is cut in half as it was too short.. can have whole kit for $150.
WTB: standard Passenger Sideskirt for R34 2door, pref in black but any will do
I have some in white if your interested? Its just the clip on attachment that fits infront of the rear wheel?
thanks damo, but i need the small part thats just behind the front wheels, no one will split a whole side-skirt it into two bits, thats why i asked for the whole one, cheers thou
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
