wanted:
1metre length of steel tube
14mm outside diameter with 1mm wall thickness (ie 12mm inside diameter)
cant find anything. can anyone help point me in the correct direction.... tried all metal suppliers down south with no luck
wanted:
Bahnerts Steel Supplies on OG Road might be able to sort you out, bit far north for you maybe but they have a decent range.
Otherwise Smart Aluminium if you're happy to have an aluminium tune
-D
-D
thanks.
need to sleeve some bolts (brake upgrade), will head out to OG rd and look/see
wanted:
You trying to sleeve R33 bolts/calipers onto Stagea/R34 hubs? :thumbsup:
Items:
550CC+ Injectors. Must be Direct replacement for R33 Series 2 RB25DET
Extra Info:
Side Fed
High impedance
Must be direct drop in
Support 300rwkw
Connectors and collars
Contact Details:
Contact via PM
Price and price conditions:
Budgets around $500
WTB 34 GTT bits
1 x driver side pillar (black), i think its the A pillar (mine has holes in it from stupid people doing stupid mods)
Valve covers for rb25det (polished preferred or stock)
2 x lef and right side console covers (ones that go each side of the radio) mine are scratch to hell.
intercooler core. Anyone got one laying around?
have a hybrid fmic sittin here. has a dent and not sure if its any good but welcome to have a suss and revel in ya old 31 ;). still dont run tho :blink:
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
