Need a few parts for clearing a defect etc, so cheaper the better. Car in question is an r32 gtst, however some rb25 parts will interchange so let me know what u have :)
Flywheel
Clutch - can be a stocker
Gearbox - rb20
tail shaft
Diff
Shockers with std height springs that don't leak etc
Rb20 Afm
Rb20 stocker exhaust or one that's 2.5" and quiet
If I can think of anymore I'll update.
Cheers
Currently chasing a few things.
- R33 stock springs either coupe or 4dr as long as stock
- R33 glovebox
- R33 Steering wheel (must be near mint no rips or sun damage etc) and must be non- airbag s/wheel
- R33 4dr driver's door power window amplifier (R32 4dr may be same)
PM me if you have any. Cheers.
Edited by RBT025
After a couple of bits for my R32 GTR..
Looking for a good clean R32 GTR drivers seat
Stock suspension
I may consider trading replacement parts for them.
RS-R coilovers that may need a reco
Recaro Seat
If you have either of these... or know a shop that has them.
Let me know!
Travis
Stock suspension
Tried to PM you on Suspension
You cannot recieve any new PM's is what I have been told by the board ;P
PM me when you've cleared your inbox out
-D
Flywheel
Gearbox - rb20
tail shaft
Diff
Rb20 Afm
updated list above in quote. Thanks for all the offers so far, much appreciated. Wouldnt be able to get the line back working without the help.
Edited by Bl4cK32
need the spacers that are used on exhaust manifold on rb25/20
there a thick round washer. after 2 of them!
pick up asap!
pretty sure i have some somewhere.
im also after a rb20 cas and rb20 tps
pm me as not in wtb section much.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
