colon's period's between numbers makes it very hard for PDA's and smart phones to ring
The Period
A period looks like this . It is used to end a sentence. You should not use a period for anything other than ending a sentence. (A period also makes up part of an ellipsis, but that's another story.)
Hey guys im after a rb25 series 2 coil pack just need 1
standard or not i dont mind just dont wanna pay to much i am getting a set soon just need 1 to get me through this missfire
Cheers
CONTACT
Jamie 0433944826
Cheers
CONTACT
Jamie 0433944826
$20
Anyone got a 3" decat pipe kickin' around the joint to suit S13/180sx? Mild or S/Steel doesn't matter none to me.
If you could drop it off to me, i promise reach arounds apon delivery as i'm currently no license spec -
PM me :cheers:
i think you would be better off getting someone like AM Performance to make up a piping kit for you. Will fit properly and you don't have to worry about buying a kit and cutting it to make it fit etc.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
