Items:
V35 sedan standard front bar
V35 sedan aftermarket side skirts and rear bar
V35 sedan HID right headlight
19" or 20" rims+tyres in 5x114.3
twin 3" tip exhaust x2
Extra Info:
preferbly in factory pearl white
not too fussed on offset. dont really mind chromies as I'm just going for a show pony look
Need full headlight including ballast module and globes
Contact Details:
pm on this site
Price and price conditions:
i can get a full kit for around 1k, so cheaper than that if possible
headlight not sure, i bought after market set for $300, i understand these are HID though
no more than 1k, found a set for $600, but wanna see what other people might have
Hey guys I'm looking for a rb20 wastegate actuator for my rb25.
Correct me if I'm wrong but the rb20 actuator runs constant 10psi compared to constant 8 psi with rb25 actuator when you ground solenoid.
Thanks
Edited by Vlasi
NEED the following for an r32 gtst:
Drivers 1/4 panel - black preferred, in exc. cond.
drivers door - again black, same as above.
Would like the following :
std exhaust to get through regency
r32 gtst std diff
rb20 engine mounts - the metal brackets, not the rubber mounts
r32 gtst headlights in good nick
Let me know how much etc,
cheers.
BTW, if you have parts (like a diff) id prefer if it was ready to go, not "ill pull it out next week" which never seems to come.
Edited by Bl4cK32
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
