RB25 turbo in good-to-excellent condition. Minimal shaft play if any ... and exhaust manifold to it too. Budget of no more than $300.
PM me if you have a turbo. Need one ASAP.
:thumbsup:
Hey guys want to buy a set of
Black 17inch 4's koya drift teks
can have a little gutter rush multi stud
call me on 0433439293 or email me on [email protected]
cheers
I have 2 17x8 with 215/45 with about 60% left on them! They are both white if you are interested pm me.
want to buy:
4 X Black drift teks 17inch
1 X R32 GTR Spoiler prefer in black - IF with boot would be even better.
Pair R32 2dr rear top trims
R32 passenger side powerwindow switch
pictures and price to 0433439293 or email me [email protected]
cheers
I'm chasing up a maual gearbox bellhousing only from the R33 GTS T.
Has anyone got any in their surplus, or a blown gearbox they are keen to split??
Cheers
I'm having an R33 gtr s2 gearbox converted to push next week, the bellhousing wont be used and will be available... if it can fit the gts-t then let me know - bellhousing is for pull system.
Cheers
-D
im after a series 1 rhs headlight to suit a r33 gtst coupe. with working adjusters.
also need a radiator (prefer a new one or refurbished one) to suit a r33 gtst series 1
radiator asap would help heaps but headlight not as important as it still works it just doesnt give me sufficient lighting.
cheers - aaron
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
