r33 parts,
series 1 antenna in working condition.
dash air vents in centre console/dash (above climate control)
gtr bumper bar indicators (clear or orange) not fussed, need bulbs and plug as all i have is wires.
235-40-18 tyres must be brand new/close to brand new as my rears are on their last legs.
r33 parts,
series 1 antenna in working condition. not needed anymore
dash air vents not neccessary but want to replace broken ones,
really do need gtr front bumper indicators with housings, or even replica ones,
still need the tyres.
text me during working hours if u have anything - 0422360999 - aaron :cheers:
Anyone have any 32 rear pods for sale?
For the noobs, its the little bit of bodykit behind the rear wheels on the back bumper.
If so, can u msg me on 0433 975 575
I rarely have time to come on here now.
