wtb- drivers side headlight for skyline v35. Shoot me a pm if you have a spare hanging around.
Cheers
have a look, its a pair but good upgrade.
http://www.skylinesaustralia.com/forums/topic/395898-qld-skyline-350gt-v35-coupe-parts-brand-new/page__fromsearch__1
WTB
  • R33 head liner (non-sunroof model), not too fussed on condition - track use only.
  • 3" cat back exhaust, preferably cannon style muffler
  • electronic boost controller
  • R33 bolt in roll cage
^^ PM Kisin he had a headliner he is throwing out GET IN QUICK it might be in the bin already
WTB
Ive got a head liner you can have its located at ridgehaven. It was out of a wreck.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
